Can I install any other oem stereo in my 4th gen?
Old May 17, 2012 | 09:50 PM
Maxieggy's Avatar
Hi guys im knew to car audio and I was wondering if I can install a newer oem nissan,infinity stereo with little to no modifications to the harnnes...
I have the original 98 double dine none bose Head Unit.
Thanks in advance.
Old May 18, 2012 | 01:41 AM
98MaximaDriver's Avatar
I think an 04-07 Pathfinder BOSE Headunit will work with lil or no modification.
http://forums.maxima.org/4th-generat...disc-bose.html
EDIT: Requires BoSE / and splicing one wire it looks like..
good luck
Old May 18, 2012 | 07:27 AM
infinimax96's Avatar
The Maxima Bose head unit will also fit. As well as speakers.
Old May 18, 2012 | 08:33 AM
cashoit's Avatar
I dont see why not.
U would need to match up the new radio wires with your car harness. prolly be cheaper AND easier to jus get an aftermarket radio
Old May 18, 2012 | 08:58 AM
SHIFT_maxboost's Avatar
ive wondered this myself. i want a double din touch screen display with cd/mp3/gps. not sure which cars have them but honestly it shouldnt be too hard to make your own harness. 12 or so wires: power,switch,illumination,ground,pos.&neg. for 4 speakers,remote and auxiliary if you have an amp and subs. someone correct me if im wrong but you find a diagram for both harness for your car and harness for the player you should be able to snip the plugs and match the wires by function not color. mounting is a different story but brackets shoudnt be hard to make either. hope this helps.
Old May 18, 2012 | 09:07 AM
Amerikaner83's Avatar
+1 on aftermarket
You could get any other 4th gen non-bose and plug in, so long as the connectors match (or rig an adaptor), or you can go to crutchfield and get one. Comes with adapter, mounting hardware, and antenna adapter, mostly plug and play!
Old May 18, 2012 | 09:37 AM
dwapenyi's Avatar
Physically it will fit. The wiring is a WHOLE other story, though. Bose and Non Bose stereos are completely different animals.
DW
Old May 18, 2012 | 02:26 PM
DennisMik's Avatar
If you put in a head unit that doesn't plug into the Nissan wire harness, get adaptors from Metra instead of cutting the wire harness.
Old May 18, 2012 | 02:42 PM
ShocknAwe's Avatar
You can put whatever you want in there but with little to no modifications you options are limited to the above
Old May 19, 2012 | 09:33 AM
Blackwind's Avatar
2002 pathfinder. No modification needed. None
Old May 20, 2012 | 04:45 AM
N3SQV's Avatar
http://www.crutchfield.com/p_130P240...T.html?tp=5684
http://www.crutchfield.com/p_113DDX3...9.html?tp=5684
Old May 21, 2012 | 01:34 AM
MrChaos10711's Avatar
Do you know of one that is like the two you posted above but uses the Droid interface. I am not an iPhone fan and only own droids but would love Pandora? Sorry op not trying to thread jack.
Old May 21, 2012 | 02:46 AM
mayur914's Avatar
You can get one that has bluetooth and sync that with the receiver and use pandora on there. As long at there is an addon on there or it already has it. The pioneer would be a better one to go with seeing that it has more options and has hd radio and bluetooth.
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MikesChevelle
Aug 6, 2015 11:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
