ok i need some help with this
Old May 21, 2012 | 05:45 PM
ibracey's Avatar
ok i am trying to put my aftermarket head unit in but i have a bose system in my 98. i have been reading that i am goin to have to re-wire everything but i dont see why i can just tap into the amp. and i am wondering where is the bose amp mounted? if someone could please help me out here. thank you
Old May 21, 2012 | 11:26 PM
infinimax96's Avatar
Each speaker is pre amped. I wouldn't recommend tapping into the stock wires. Buy a wiring harness for the bose unit and wire your aftermarket headunit into that.
Old May 22, 2012 | 12:05 AM
You read some bad information. All you need to get is the right plug and plug wiring harness to connect your new headunit to the existing harness and you're done.
Shop Crutchfield and you'll see what I mean. They include all the necessary harness(es) and dash kits necessary for install, free of charge.
Old May 22, 2012 | 04:00 AM
ibracey's Avatar
ok well this is the one i have coming to me in a few days. the head unit i have has extra amp hook ups on it. http://www.amazon.com/Metra-Amplifier-Integration-995-2005-Infiniti/dp/B0007WTF5C/ref=sr_1_5?ie=UTF8&qid=1337684348&sr=8-5
do i just hook the wires into them and it should work right?
Old May 22, 2012 | 09:50 AM
clint240sx's Avatar
Looks like it will work, I would just replace the head unit as well. Better output.
It looks like that intergration kit has a pre-amp output.
Good luck
Old May 22, 2012 | 11:22 AM
tosheto's Avatar
http://www.amazon.com/Metra-Amplifie...ype=automotive
http://www.sonicelectronix.com/item_...a-70-7551.html
Old May 22, 2012 | 11:51 AM
Stonelove670's Avatar
Old May 22, 2012 | 04:14 PM
ibracey's Avatar
well i thank you all and the part should be here in three days hopefully
Old May 22, 2012 | 06:49 PM
RA030726's Avatar
I'm nutty for Nissans
I had an inline converter years ago. It lets you adjust the levels coming from the HU to the Bose amp. They work OK. At some point I decided to take it out. I now have the pre outs sending the signal directly to the Bose amps. Its basically the same thing as the above links but essentially free. Works great.
Old May 23, 2012 | 06:15 AM
ibracey's Avatar
ok i have another question. when i turn the ac on the air only comes out through the outside vents not the 2 inside ones. does anyone know what i can do to make them work?
