Are there MOOG ball joints for LCA with zerk for the 4th gen?
Old May 24, 2012 | 09:35 AM
atriuum's Avatar
I looked at rockauto and partsgeek, but the MOOG ball joints they sell don't have the zerk fittings, at least that's what the photos show.
Are there MOOG ball joints for the 4th gen with Zerk?
Thanks.
Old May 24, 2012 | 09:41 AM
max_dreamer's Avatar
Not that ive seen... I buy mine from Nappa and they typically show you all the products but may not carry them. I dont believe they have the zerk fittings on them...
Old May 24, 2012 | 11:36 AM
atriuum's Avatar
So it's basically MOOG sway bar end links and MOOg tie rod end links with zerk?
I saw MOOG lower ball joints with zerk on amazon but those are for chevy and co. I thought they might have 'em for the 4th.
Old May 24, 2012 | 11:46 AM
asand1's Avatar
drill em, tap em, and install your own zerks.
Old May 24, 2012 | 02:06 PM
atriuum's Avatar
Ok. So that will work? I'll be able to service them without damaging them?
Old May 24, 2012 | 04:22 PM
RA030726's Avatar
I'm nutty for Nissans
Yes, I just helped my cousin install a moog bj with the grease fitting.
Old May 24, 2012 | 08:59 PM
asand1's Avatar
Idk, but I would try. Not in the body, but in the pressed in plug looking part on the back side.
Old May 26, 2012 | 09:16 PM
surban1's Avatar
i looked around for em but couldn't find with zerk for our max's. i'd be concerned about introducing metal slivers by drilling & tapping in a zerk.
Old May 28, 2012 | 08:00 AM
NABU6's Avatar
The moog's I installed on my car and ordered from Rockauto has them. Dont go by the picture, due to the fact that the picture might not be of the actual product. Order from them, if not what your looking for, send them back.
Old May 28, 2012 | 08:56 AM
Are you sure you picked up Moogs? Moog's website doesn't mention or show a ZERK fitting... Can you check your order history and pull the part number for them?
Old May 28, 2012 | 09:17 AM
MaximaSpd85's Avatar
Do the moog parts have some kind of identifying stamp on them? Id be concerned that im actually getting a real moog part rather than some off brand part in a moog box.
Old May 28, 2012 | 09:21 AM
NABU6's Avatar
Yes, the part number on the Rockauto web site is K9818. Matter of fact, if you read the description, it states that they come with grease fittings (Zerk)
http://www.rockauto.com/catalog/moreinfo.php?pk=227575
The picture doesn't show it, but the fitting goes on at the botton of the ball joint. The ball joint has to be pressed on the control arm first, then the fitting screwed in.
Old May 28, 2012 | 09:26 AM
sure nuf... Shame on Moog for a shauty website description! Kinda sad mine didnt have the fittings...
Nothing at all said about them here
http://www.moog-suspension-parts.com...rod=MOOG-K9818
Old May 29, 2012 | 04:04 PM
edwardh1's Avatar
e mail moog and whoever else makes them
MAXSE5SPD
Sep 17, 2022 04:00 AM
AaronL
Nov 15, 2020 11:52 AM
Bonka
Sep 14, 2015 11:18 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
