Transmission Fluid Change Question?
Old Jan 5, 2002 | 03:24 PM
max808's Avatar
Complete Drain and Fill?
I read somewhere that this procedure should work to completely drain and fill with new ATF.
1. Drain old ATF from drain bolt (about 4 quarts)
2. Fill new ATF from stick (about 4 quarts)
3. Disconnect return line to ATF pan from radiator.
4. Start engine and catch old ATF from return line (no more than 4 qts)
5. Connect return line (prior to refilling)to prevent spilage while refilling
6. Fill new ATF (about 4 quarts)
7. Disconnect return line to ATF pan from radiator.
8. Start engine and catch old ATF from return line (no more than 4 qts)
9. Connect return line (prior to refilling)to prevent spilage while refilling
10. Fill new ATF (about 4 quarts)
11. Disconnect return line to ATF pan from radiator.
12. Start engine and catch old ATF from return line (no more than 4 qts)
13. Connect return line (prior to refilling)to prevent spilage while refilling
14. Fill new ATF (about 3 quarts)
15. Check level and top as necessary
Thoretically this would remove all ATF and replace with new ATF. Downside, you waste some ATF. Upside, you don't let the grease monkey boys at Jiffy Lube touch your car.
What do you think about this method? Thanks.
Old Jan 5, 2002 | 06:00 PM
brubenstein's Avatar
You have more steps than you need. After you do the pan drain and refill, disconnect the return line (I connect it to a 6ft piece of tubbing with a male-to-male fitting so I can see the container with the engine running.) pump out 2 qts (you dont want to suck air), shut it off, refill the sump (you don't have to connect the return line) and repeat until clean fluid comes out. When you're done get the fulid up to operating temp and recheck the level.
Old Jan 5, 2002 | 07:28 PM
1MAX2NV's Avatar
Or just pay $79.99 and take it to Jiffy lube
or any shop that has a tranny flushing machine. I believe it's called T-Tech.
Old Jan 6, 2002 | 12:37 AM
max808's Avatar
Return Line
The return line is the one on the passenger side of the radiator right?
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
