How do you guys keep your Y pipe gaskets sealed properly?
Old Jun 16, 2012 | 06:07 PM
shadyonedeath's Avatar
I seems that everytime I replace them (which as been around 12 times now), they always leak after riding over hills/bumps/pot holes that twist the chassis around.
Whats the secret? Am I getting the wrong part? My choice were the ROL type from Oreily's, that are thicker than the Fel-pro type. But im up to my neck with these things...such a ****ty design. It seems like they always get warped unevenly inside the gasket groove from heat/torque/unknown.
I tighten the bolts one at time @ small increments to get a even press. But even when I replace them, they're always warped/uneven/un-parallel to the flange at certain locations of the gasket groove.
Old Jun 16, 2012 | 06:48 PM
MAXIMA_STYLE's Avatar
Oem....
Old Jun 16, 2012 | 07:07 PM
T_Behr904's Avatar
Worn motor mounts can also cause the exhaust to shift around excessively. Wouldn't hurt to check that out.
Old Jun 16, 2012 | 08:41 PM
wirelessdude04's Avatar
Yea alot of vibrations will cause that
Old Jun 17, 2012 | 07:05 AM
RA030726's Avatar
I'm nutty for Nissans
RTV red
njmaxseltd's Avatar
If any of the flange mating surfaces are not flat, the gasket will blow out at the weak spot.
I had to replace my main cat just recently because of this.
Old Jun 17, 2012 | 10:54 PM
Dhione's Avatar
I took my y pipe to autozone and looked at all of there gaskets and found a nice set of metel ones that i have not had any leaks with.
Old Jun 18, 2012 | 01:31 PM
carsnwomen91's Avatar
... ugh they're supposed to be metal lol. Only on a scooter will you see a non metallic exhaust gasket. You shouldnt be replacing it so many times, I have whatever warpspeed gave me and they work fine. Id go with oem... then follow tbehr's suggestion cause that's really excessive gasket wear
Old Jun 18, 2012 | 01:39 PM
ShocknAwe's Avatar
lol a Cattman Y with good flanges
JRod28
Dec 29, 2023 09:56 PM
FlaMark
25
Aug 28, 2015 10:15 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
