ac vent question
Old Jul 4, 2012 | 07:16 AM
ibracey's Avatar
ac vent question
ok so i got my ac charged the other day but when i run it it only seems to come out the driver side real good and the middle some what and like nothing on the passage side. is there something i can do to make it work right? thanks in advance
Old Jul 4, 2012 | 08:32 AM
max ride 41's Avatar
yeah, you could search, that would be nice
Old Jul 4, 2012 | 09:22 AM
DennisMik's Avatar
I assume this is a recent happening, that the vents used to all have good air flow? Finding the source of the problem will be tough. One of 3 things is happening. Either something got into the vents and is blocking the air, the mode door motor is not working correctly or one of the air doors has come loose and is causing the blockage.
Something int the airducts is pretty unlikely, the a/c evaporator core acts like a filter for something like this.
The mode door motor theory could be checked by removing the motor and moving the arm manually while the blower motor is running.
To check for a disloged air door, I think you would have to pull the dash out.
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
