installed stereo, now 1/2 of my Climate control lights don't light up
Old Jan 6, 2002 | 06:51 PM
climaxing's Avatar
I installed my stereo last week and now over 1/2 of my climate control button lights don't work anymore and the ones that do are really dim? It is only the buttons that seem to be affected. It is weird, on the temperature part, the blue down arrow work but the red up arrow doesn't work. Nothing past my Defrost button works. This doesn't make sense. I need your help on this one guys!
Old Jan 7, 2002 | 08:33 AM
97MaximaGLE's Avatar
Re: installed stereo, now 1/2 of my Climate control lights don't light up
I had the same problem happend, i never dropped anything, i was very careful?? not sure what happened? Anyone else have this problem?
Old Jan 7, 2002 | 08:59 AM
ejj's Avatar
ejj
Did you guys re-check that you pluged everthing back into the CC unit correctly?
Old Jan 7, 2002 | 10:33 AM
ny96max's Avatar
make sure that all clips behind the CC unit are snug and locked in place!
Old Jan 7, 2002 | 11:47 AM
95emeraldgxe's Avatar
u prolly tugged on the panel to hard or sumthing.....check if all the friction/clip fittings are where they supposed to be
Old Jan 7, 2002 | 02:47 PM
iansw's Avatar
Or maybe you snipped the wire for that half of the lighting while installing your deck?
Unlikely, I know, as it's probably only one wire going there, but something to think about.
Old Jan 7, 2002 | 03:58 PM
climaxing's Avatar
All clips are snug, does anyone know I can run another wire to those bulbs and get light from somewhere else? Although, I imagine that isn't too easy. I did tug pretty hard on that side unit, but those factory wires are suppossed to be able to with stand some force, right?
Old Jan 7, 2002 | 07:26 PM
nick1020's Avatar
The exact same thing happened to me when i had my system put in. A couple lights no longer worked in the climate controll and the red arrow and defrost didn't work either. I just went to a nissan dealer got a couple lights and pluged them in and they worked fine after that.
Old Jan 7, 2002 | 07:51 PM
climaxing's Avatar
Nick1020,
Are you saying you just had a couple of burn out light bulbs?
MikesChevelle
Mar 2, 2021 11:32 AM
rtirbany
Sep 8, 2015 11:46 AM
Samedi
Aug 13, 2015 04:05 PM
