The definitive radiator core support thread
Old Dec 11, 2016 | 08:51 AM
  #41
skywalker85's Avatar
As many of you may know the radiator core support is a known "weak point" on the A32 chassis. This is an extremely common issue among A32's from "wet" states. This thread will address a number of key points with this issues
1)Signs of a bad radiator core support
2)How to replace said radiator core support
3)And why you shouldnt use a cheap radiator core support
I:
lets start off with spotting a failing core support (NOTE: The images shown are of very, very badly rusted supports) .
II:
we move on to How To replace the core support and what is the proper parts to be used and where you can purchase them.
To correctly replace the core support, the old unit will need to be cut out and the new unit will need be be bolted and welded in place..This job is definitely not one of the easier things to do an A32 and will likely need to be done by a professional or a fairly knowledgeable DIY mechanic with access to air tools and a welder.
Their are two common methods to to replacing the core support; one is replacing just the lower support (under the radiator) and the other is replacing the entire front core support. Either of these parts can be sourced at your local Nissan dealer or through a reputable online dealer such as Courtesy Nissan Parts.
PARTS
  • This link takes you the Front Apron & Radiator Core Support diagram and parts list LINK
  • The part number through Courtesy for the entire support is 62500 and HERE is a link.
  • The part number through Courtesy for the lower support is 62530M and HERE is a link
I'm not going to post all of the info in the following threads ... please follow the links for more information
JSutter - How to: Radiator support on life support.... fixed!
95naSTA - Lower Radiator Support Replacement Pics
http://forums.maxima.org/4th-generat...nt-photos.html
III:
we will move on to why you should buy an OEM core support and not a cheap piece off of ebay or rockauto. This is one of those things that "if it sounds too good to be true, it probably is"...meaning that $50 coresupport on ebay may sound like a steal of a deal right now, but 3 months down the road when you notice your engine cradle is sitting 3 inches off the ground and you have to pay to do all of this work again, you will wish that you had just spent the extra money to begin with because in the long run an OE piece is going to be the cheaper AND better investment.
I will let the images speak for themselves
If you believe anything should be added or changed please let me know.
Anyone know where I can get these cross member bolts from?
Old Dec 11, 2016 | 08:55 AM
  #42
maximaxi's Avatar
Does anyone here spray Krown on the support?
Old Dec 11, 2016 | 07:25 PM
  #43
I Hercu lined mine inside n out few weeks ago..
Old Dec 13, 2016 | 10:16 AM
  #44
maximatech12's Avatar
Salvage yard
Just need extra battery juice for your cordless drill.
Ya just sand the part down with fine grit sandpaper then prime a few times, paint, then clear coat.
Old Jun 25, 2021 | 11:53 AM
  #45
daturadiablo's Avatar
Originally Posted by maximatech12
Salvage yard
The OEM part is made up of 18 gauge steel, however the center section is doubled up internally with a 9" wide 13 gauge piece in U-shape, tack welded to the box on all sides. Replacing mine after 23 years and 157k miles. Cleaned up the thread of the 17mm bolts with thread repair file and threading die.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
