will 5th gen hood struts work on 4th gen?
Old Aug 14, 2012 | 02:48 PM
kingrukus's Avatar
no more maxima...
does anyone know if the 5th gen hood lift support struts will work on a 4th gen?
thanks
Old Oct 9, 2012 | 08:57 AM
kingrukus's Avatar
no more maxima...
bump
Old Oct 9, 2012 | 09:01 AM
Spencer5556's Avatar
They are pretty universal. I would assume so. I bought universal ones for my 4th gen
Old Oct 9, 2012 | 09:17 AM
DennisMik's Avatar
I replaced the struts on my 97 and 2000 and found out that they are physically different sizes. IIRC, the 2000 struts were the larger ones, but I could have it backwards. The size difference was both length and thickness. The length part could keep you from closing the hood.
Old Oct 9, 2012 | 09:18 AM
kingrukus's Avatar
no more maxima...
good to know - thanks
Old Oct 9, 2012 | 09:48 AM
GGENIUS's Avatar
plus, just why? theyre both cheap on ebay.
Old Oct 9, 2012 | 10:24 AM
njmaxseltd's Avatar
Or your local auto parts store. Advance, Straus, NAPA Etc...
Old Oct 9, 2012 | 10:27 AM
kingrukus's Avatar
no more maxima...
I have a pair of 5th gen hood struts that a 4th genner was interested in.
Old Oct 24, 2012 | 07:57 AM
Ritz's Avatar
I'm working in a parts store at the moment and comparing them. It looks like the 5th gen struts are slightly longer (1/8" or so) overall, but the cylinder part of it is shorter, so it won't restrict the hood from closing. The only other difference I see is the clip on the cylinder side has a slight angle to it. I doubt it would cause a problem but I will try it on my lunch break and report back.
FYI, I'm also looking for struts that are about 1-2" longer overall but have a shorter or same size cylinder so the hood can raise a little higher. I'll post my results for that as well.
Old Oct 24, 2012 | 12:03 PM
Ritz's Avatar
5th gen hood struts worked for me. At least Strong Arm ones did, but I'd assume they're all close enough.
Didn't find a longer one yet. It's gotta have the angled clip on the strut mount joint. I found one that was straight, but it wouldn't fit properly.
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
kenc15
Aug 5, 2015 08:29 AM
