ashtray fuse?
Old Aug 22, 2012 | 08:18 PM
joew's Avatar
ashtray fuse?
Is there an ashtray fuse. I don't see it under the dash fuse box so I assume there is no fuse for it. Interested in replacing the light.
Old Aug 22, 2012 | 09:26 PM
DennisMik's Avatar
The ashtray light does not have its own separate fuse. It is part of the dashlights, so if you have the glovebox light, shiftlever light (auto trans) or any dashlights, you probably have a burned out light bulb.
Old Aug 22, 2012 | 09:36 PM
BigLou55's Avatar
Yea that one of the first bulbs to go out, just replace it with an led and you should be good to go
Old Aug 22, 2012 | 10:52 PM
maxinout93's Avatar
does the a/c control have bulbs to light it up also? it only lights up at night if I turn it on, other than that I have to feel my way around to see the buttons.
Old Aug 22, 2012 | 11:36 PM
max ride 41's Avatar
if its am auto - climate then yes it should light up even with the lights off. standard or manual climate if its dark then the bulb is burned out.
Old Aug 23, 2012 | 12:03 PM
bobflood's Avatar
Both the auto and manual A/C controls have bulbs that light up the controls at night. Auto control bulbs pretty easy to replace; I assume manual will be the same. Pull the unit out of the dash and look at back; there should be 3 or 4 small round plastic pieces with a slot in them. Those are the bulb holders. Bulbs are #74 (I think?) and readily available at most auto parts stores. You can switch to LED - just watch your polarity as it matters for LED.
Old Aug 23, 2012 | 12:12 PM
maxinout93's Avatar
yes it is auto climate control. but thanks for the info I will try to replace the bulbs.
leatherneck
Sep 30, 2015 09:16 PM
Junebug1701
Sep 25, 2015 01:54 PM
conansriver
Sep 16, 2015 12:17 PM
jwright36
Sep 8, 2015 11:45 AM
