cel won't self test, failed inspection.
my check engine light won't come on anymore. it had been on and off with a p0400 code. i replaced and cleaned everything except the egr control solenoid, only can find it for $200+. In NJ the CEL has to self test out when turning on the key to pass. I assumed i burned the bulb out, pulled cluster, bulb is fine. checked the printed circuit board with a test light, and found voltage to the bulb, but it appears the strip goes back to the plug in connector to get its ground, and its not getting a ground from the connector. i'm assuming the ECM would be controlling the ground. Could this be due to the fact that all the drive cycle monitors haven't cleared?? it still has the EVAP and Cat Efficiency not ready. the only thing i can think of is the ECM is bad, or the monitors have to clear first. any help would be great!!
Did you pull codes with the screw on the side of the ecu? If so, make sure it's back in the center position. The cel should come on when the key is turned to the on position. That happens with or without a ready condition.
Here is a link to a video on how to pull codes using the ECU.
Here is another link that you should save. It is a playlist fot a bunch of how-to videos.
http://www.youtube.com/view_play_lis...E3C3345DC2C64F
thanks guys, well the light came back on...good and bad. now i gotta figure out what is causing the p0400. i've replaced the egr valve, egr tube(i broke it coming out), cleaned the intake and the dohicky with all the sensors and stuff on the side of the intake. Any way to test the EGR Control Solenoid that supplies vacuum to the solenoid??
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
