Turn signal help!
Turn signal help!
So I got some exterior LED's today and when I was trying to get the front turn signals to work (i didn't know that they don't work in the front) with LED, the left front one stopped working.
I put the OEM bulbs back and the turn signals are as follows:
Hazard lights=both flash normally. left front out
right turn=flashes normally front and back.
left turn= flashes fast in rear and front is out.
EDIT:Yes I tried a different bulb.
Any ideas? HELP!
Any ideas? HELP!
Have you checked inside the socket to see if it is clean and not corroded? Also check the back side of the socket to see if there is any corrosion problem where the wires go in.
And there is no reason for the LEDs to not work - except possibly reverse polarity.
It's not a fuse problem. There is only one fuse that covers all the lamps.
When I get my front left socket to work, do you think that these would work fine to A: get them to work in the fronts and B: to stop the fast blinking?
http://www.ebay.com/sch/i.html?_saca...ecoder&_sop=15
http://www.ebay.com/itm/Car-Load-Res...item2c670e90e5
Those are the type of resistors I used for my led bulbs. 4 of them, one for each bulb.
There are some people that also just switch out the flasher relay, which I might eventually do for a cleaner look.
To make LEDs work in the front, you have to chop off both wires and re-splice them in reverse. Basically, when you cut Wire 1, you reconnect one end of Wire 1 to the other end of Wire 2, and vice-versa. This is the ONLY way LEDs will work in the front turn signals. Been working fine for over 2 years.
Also, to stop the hyper flashing, there is no need to wire in resistors. Get the NISSAN LED flasher relay from autolumination.com, swap it in and there you go.
That's the ONLY way to get the fronts to work? I want to do the least amount of wiring possible.
The LED relay sounds like an easy and cheap fix to the hyper flashing
I just did it a couple weeks ago, got the relay as well ($20.99 shipped) and it works nicely, only took me about 5 minutes to rewire.
I recommend using heat-shrink butt connectors (to weatherproof the wires) unless you're going to solder and heat-shrink the wires.
Trust me, I don't like messing with any wires but this wasn't too bad. Just flip the wires and its all done.
Wire gauge for what? You just cut both wires from the socket off and flip them. You can cut like 2 inches from the bulb socket. No need to add extra wire.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
