98 Cluster Wiring Help needed, please help
Old Sep 11, 2012 | 12:01 AM
tryingtobebest's Avatar
Hi, im doing a little project so i would really appreciate if someone give me a link or post some information about Cluster/ Dashboard/ Speedo wiring/ diagram/ schematics for 98 Maxima.
I know that 3 of them should be:
Temp
RPM
Fuel Level
And most likely an Airbag light
But which one is wich???
Please help, need this ASAP!
Here is 6 wires that im after
If this is not in the right section, im bringing my apologies
Old Sep 11, 2012 | 09:41 AM
DennisMik's Avatar
In your photograph, the connector that has the wire harness on it is connector M82. As your photo shows it, the top left corner is pin # 14 and the numbers count down to # 7 as you go to the right. The bottom row, left side is pin # 6 and counts down to # 1. You are asking about pins 2, 3, 4, 5, 13 and 14.
#2 = VSS
#3 = tachometer
#4 = VSS
#5 = gas gauge
#13 = air bag
#14 = coolant temp
The source of this info is the 1998 Nissan service manual, section EL, pages 70 and 71.
Download manual from:
http://boredmder.com/FSMs/Nissan/Maxima/
Since the 95-97 cluster is not swappable with the 98-99 cluster, I have to assume that you are making custom wire harnesses. I wish you luck.
Old Sep 11, 2012 | 06:49 PM
THANKS ALOT for the link, very very informative!)))
PS im not putting it to Maxima doing a project on Skyline!)
Slamrod
Apr 10, 2016 05:24 PM
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
doobadoo
Aug 15, 2015 06:43 PM
maximaham
Aug 7, 2015 01:11 PM
