Power steering fluid filter
Old Sep 12, 2012 | 11:48 AM
asand1's Avatar
Any one ever installed one? From what I've read, it virtually eliminates pump and rack failures.
Old Sep 12, 2012 | 12:46 PM
cashoit's Avatar
not me, but should be easy to install.
My only concern is starving the pump of fluid since now u are introducing a flow restriction that nissan did not account for. And depending on the screen size the pump may not have enough "suction" power to work properly.
my .02.
Have u noticed metal shavings in the reservoir or is something wrong?
Old Sep 12, 2012 | 12:49 PM
njmaxseltd's Avatar
200,000 miles & 13 years later - no filter, no problem.
Old Sep 12, 2012 | 01:02 PM
I wouldn't bother with one.
Old Sep 12, 2012 | 01:58 PM
asand1's Avatar
No, I have no problems but I've been seeing threads lately about racks needing replaced. The return line to the reservoir is still being pushed through by the pump, its just not under pressure because there is no head. I just thought it would be cheap insurance.
Old Sep 12, 2012 | 04:23 PM
Rob_0126's Avatar
Had the rack replace a few years ago. It was leaking like a siv, as well as the pump. (113k miles at the time)
The pump has quieted down a bit over a year, and I use synthetic atf for insurance.
Wish the reman'd pumps didnt whin so much.
Old Sep 12, 2012 | 04:32 PM
ShocknAwe's Avatar
Its a sealed system, no contaminants should get in and if you are changing regularly like you should? no need
Old Sep 12, 2012 | 05:32 PM
asand1's Avatar
Wrong, the cap is vented.
Metal and rubber from the system itself.
You change your engine oil regularly, so I guess you don't need an oil filter then?
lowpost99
Oct 26, 2025 06:53 PM
captchaos
Mar 15, 2016 12:18 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
