Thing you push on door to open the trunk
Old Sep 13, 2012 | 01:42 PM
edwardh1's Avatar
99 infiniti
can you replace the push button with the newer style that you have to PULL on?
mine keeps getting hit by accident.
does the newer style (oo and up?) fit in the same hole in the door?
Old Sep 13, 2012 | 02:43 PM
sow3r's Avatar
theres a safety lock on the trunk near the latch. push it down and it will prevent the trunk from opening with the button, but also with the remote so you will have to it with the key.
Old Sep 13, 2012 | 02:50 PM
edwardh1's Avatar
the newer button pulls out, the old (99) pushes in- another place where nissan has clueless ergonomics.
My question is will the new button from 00 and up fit in the 99 door hole?
Old Sep 13, 2012 | 02:56 PM
ShocknAwe's Avatar
Anything will fit with modification. I think the later button is thinner though because the gas door button is next to it as well. I don't see how you hit it by accident though I can say I have never done that
Old Sep 13, 2012 | 03:00 PM
edwardh1's Avatar
thats why they changed the design
tigersharkdude's Avatar
OP, you could always pull the door panel off and unplug the trunk release switch
Old Sep 13, 2012 | 03:11 PM
GGENIUS's Avatar
well usually when im in my car i know that its there, so i avoid flailing my limbs in that specific spot on the door.
Old Sep 13, 2012 | 04:04 PM
MaxiNone's Avatar
op, you could always pull the door panel off and unplug the trunk release switch
+1
Old Sep 13, 2012 | 07:46 PM
DennisMik's Avatar
I looked at my cars and to put the pull type button into the 4th gen would be a big project.
The 5th gen button is bigger due to the fact the gas filler door button is part of the switch. It is not 2 separate switches. 4th gen = 3 inches wide, 5th gen = 3.5 inches wide.
Because the 5th gen is 2 switches in one, the the wire harness connector is a 4 wire connector vs a 2 wire connector on the 4th gen.
And the real killer - the shape of the door panel. The 4th gen door panel is almost flat where the trunk switch is located. on the 5th gen, the trunk switch is mounted in a curved portion of the door panel. The 5th gen switch is molded to match that curve.
Personally, I wouldn't mess with it. More trouble than it's worth.
Old Sep 14, 2012 | 03:39 AM
edwardh1's Avatar
Thanks- that kills it. too hard.
Old Sep 14, 2012 | 06:21 AM
DjHackStyle's Avatar
I got a better idea for you, that trunk switch is a "normally open" switch and when its pressed it connects the two wires together and opens ur trunk.
You can buy a regular "normally open" push button in radioshack any style you like and mount anywhere you want and just run the wires to it, and disconnect ur current trunk switch but leave it in place.
A good place to mount the switch is in the blank spots near the vents or some where on the under dash panel.
trust me not that complicated you can do it.
Old Sep 14, 2012 | 06:28 AM
aackshun's Avatar
You obviously don't drive your car hard enough
Old Sep 14, 2012 | 06:58 AM
MAXIMA_STYLE's Avatar
LOL thats awesome!! But i still cant see someone hitting the switch hard enough to pop the trunk... mine is disconnected in my 99... then again idgaf cause my viper fob opens my trunk...
Old Sep 19, 2012 | 01:51 AM
mightyMax95's Avatar
hahaha, he just about fell out of the car on that run
Old Sep 19, 2012 | 06:17 AM
cashoit's Avatar
This.
Exactly why i wd just disconnect the switch if it was THAT much of a pain.
I wouldnt expect anything less Aack mang lol
Old Sep 19, 2012 | 11:38 PM
and you don't drive your car at all, heh heh heh
Old Sep 20, 2012 | 05:35 AM
max1008's Avatar
Mine isn't in the door...it's in the floor. Pull to open trunk, push to open gas door. I like this better!
Old Sep 20, 2012 | 02:44 PM
aackshun's Avatar
Jo0o funny mang
Pauper
Old Sep 20, 2012 | 02:47 PM
ShocknAwe's Avatar
Dead pedal Bish I dont rest my foot when driving. I use it to brace myself
Old Sep 22, 2012 | 05:52 AM
rf97's Avatar
I've owned my car for 16 plus years never once did i accidentally hit that button, if you're not paying attention
Shxit happen. I guess there's always the .009 percenters
Old Sep 23, 2012 | 12:31 AM
whiteSE's Avatar
haha. that **** happened to my 97 maxima a couple times.....go into a corner. trunk opens lol
Old Sep 23, 2012 | 01:06 AM
LadyMaxLuvr's Avatar
I'm so happy I'm not alone in flapping trunk due to untimely button activation while driving.
Funnily, I used to do it all the time when I first got the Max, now, not so much.
Old Sep 23, 2012 | 08:02 AM
theWalkinator's Avatar
Thanks for the info. I got hit lightly from behind while ago in traffic and since there was no damage on the rare bumper, I let the guy go but when I got home I found out I cannot open the trunk with remote or the button on driver side door panel, has to use key to open the trunk until I saw this and I opened trunk with key, unlock the latch and remote and button work again! I guess it was that when the car got hit, the safety latch closed due to the shock.
Old Sep 23, 2012 | 09:51 AM
Nealoc187's Avatar
SLOW
hitting that button unintentionally has never even crossed my mind. how are you hitting it, with your knee or thigh? and what are you doing moving around that much lol.
Old Sep 24, 2012 | 12:16 AM
whiteSE's Avatar
i tap it with my thigh.
Old Sep 24, 2012 | 09:51 AM
Shift_A32B's Avatar
Old Sep 24, 2012 | 09:54 AM
ShocknAwe's Avatar
You guys must have short legs. No way in hell I could hit it with my knee even if I tried or my thigh for that matter. Get a dead pedal and problem solved
Old Sep 24, 2012 | 03:58 PM
In my case it's from being broad in the beam. After I learned to stop carrying anything in my left pocket (and behave myself zipping around corners), problem resolved.
Old Oct 27, 2012 | 07:03 PM
cjanderson3's Avatar
Here's an idea..
-Get a small push button, one that mounts through a small hole
-Take off the door panel
-Find a spot near the trunk release to mount you second button, preferably so that one hand can reach both buttons
-Cut one of the two wires going to the trunk release
-Splice in the new push button
This way you have to push two buttons at the same time for the trunk to open
(ergonomics FTW )
Old Oct 27, 2012 | 07:05 PM
I don't want this to come across as thread-jacking or anything...
...but if anyone can help with my trunk release install that would be just really damn peachy lol
here's the link-
http://forums.maxima.org/4th-generat...ml#post8649730
Old Oct 27, 2012 | 11:40 PM
EvanMax41's Avatar
i don't have to worry about accidentally opening my trunk, my sub-woofers broke my truck release i can only get in through key entry lol. do i care no lol
Old Oct 28, 2012 | 06:27 PM
Trini Boom's Avatar
Maybe the OP may want to look into possibly wiring the trunk open button with the car either in P or N only...
Old Oct 28, 2012 | 06:53 PM
AlexxSCM's Avatar
You one short muthufvcka!
Relocate it on your steering wheel.
Old Oct 28, 2012 | 07:47 PM
Now thats a helluva idea, it'd be sweet if someone knew how to do it lol
Old Oct 28, 2012 | 09:09 PM
AlexxSCM's Avatar
Good idea
Old Oct 29, 2012 | 08:14 AM
GGENIUS's Avatar
try tapping into a wire to the neutral safety switch
dcam0326
Sep 7, 2015 07:26 AM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
