rebuilding engine
Old Jan 8, 2002 | 11:01 AM
NISMOPower's Avatar
rebuilding engine
I have a few problems with my max like a main oil pan leak and probably a water hose. I also here some wierd noises when my rpms get higher as i drive as if something was loose and shaking or like a low tone growl but not really that loud? Should I rebuild my engine, and just replace and try to find out the problems? I have a 97 GLE.....What should i do? If i do rebuild i would probably rebuild it to make it stronger and maybe get a 5spd conversion or vb mod. Is there any other thing to do to make my engine better than average????
Sorry so long......
Chris
Old Jan 8, 2002 | 11:13 AM
Cumalot's Avatar
Don't you mean rebuilding your transmission perhaps? From how you are describing it, it seem like it's your tranny that is going not your engine. I'm thinking about the same thing. I am planning to get a Level Ten rebuild on my automagic tranny.
Old Jan 8, 2002 | 12:00 PM
SuDZ's Avatar
Would an oil pan leak constitute having to do a whole engine rebuild?
SuDZ
Old Jan 8, 2002 | 12:16 PM
95emeraldgxe's Avatar
did u ever take your dash board apart before?? - maybe that may constitute to the extra noises??
Old Jan 8, 2002 | 12:25 PM
matty's Avatar
Just fix the Main Oil seal...and that extra noise could be from something lose. Get it looked at ! Dont rebuild your hole engine for a $25 seal(All labor to replace) and a bad hose ??
Old Jan 8, 2002 | 12:28 PM
SuDZ's Avatar
Exactly what I meant. You nmay find it to be something much cheaper and easier than you think. have you had the car looked at yet?
SuDZ
Old Jan 8, 2002 | 12:33 PM
matty's Avatar
It's a 97', I doubt anything serious is wrong with your engine...these VQ's are great engines
Old Jan 8, 2002 | 01:45 PM
Steve Marsh's Avatar
what is the mileage on your VQ?
Old Jan 8, 2002 | 11:14 PM
NISMOPower's Avatar
I have about 74000 miles, I drive my bar pretty hard.....It seems like something is rattling or loose. It only happens when i'm in gear and at low rpms when i start to take off at but i don't put down too much gas...
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
maximusrising
Sep 2, 2015 09:55 AM
