rpm/tach NOT MOVING AT ALL!!
Old Oct 22, 2012 | 11:08 AM
Tokesalot's Avatar
Tach Gauge Not working!!
so i sintalled the stillen grounding kit on my 99 I30 and stupid me i didnt bolt one ground and tried starting the car.. lights were flickering with ignition pulses and within 2 or 3 seconds i stopped trying to start the engine, checked wiring and tightened the screw, crossed my fingers and she started!!! BUT now my tach is not working at ALL! is this controlled by a fuse/relay or did i screw myself??
any input would help
Old Oct 22, 2012 | 11:10 AM
Amerikaner83's Avatar
do the rest of the gauges work? speedo / gas / temp?
Old Oct 22, 2012 | 11:11 AM
ShocknAwe's Avatar
most likely blew a fuse or the connection on the back of the gauge is no good anymore
Old Oct 22, 2012 | 11:22 AM
Tokesalot's Avatar
YEA its wierd everything else is functioning normally
Old Oct 22, 2012 | 11:23 AM
Tokesalot's Avatar
is there a dedicated fuse??
Old Oct 22, 2012 | 11:24 AM
ShocknAwe's Avatar
were you smoking when doing this work? Take the gauge cluster out and take a gander at the back of it. If it is black lol, you need a new one
Old Oct 22, 2012 | 11:30 AM
ShocknAwe's Avatar
Could have blown the capacitors as well. If it is not moving at all then you need to locate a pull a part in which to buy another one
Old Oct 22, 2012 | 11:32 AM
Tokesalot's Avatar
lol lol had a J in my mouth and a piece in my hand!!! J/K
Old Oct 22, 2012 | 11:37 AM
I believe you.
Old Oct 22, 2012 | 11:39 AM
Tokesalot's Avatar
i will check the back!! stupid question... is mileage stored in ecu or gauge
Old Oct 22, 2012 | 11:51 AM
mileage is stored in a chip in the gauge clsuter
Old Oct 22, 2012 | 12:08 PM
ShocknAwe's Avatar
Not musch you can do when it totally stops working. If it is just going crazy then you can solder it back up and replace the capacitors but you likely blew them up. Electrical work seems easy until you make a stupid mistake and it costs you.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Marc2theMax
Sep 28, 2015 08:13 AM
