Clock and Cd player Wont Work
Old Oct 30, 2012 | 03:42 PM
NissanHottie's Avatar
Ok I just bout a 97 maxima The clock wont come on at all and the cd player wont take a cd when you try to put one it it get tight like there something in it but nothing comes out nor makes a noise. Im new to the nissan world so don't know to much about them then again im a girl who don't know anything about cars I tried to pull a fuse to see if that was it but could only get one out and it was still good.. Thanks for your help. Any will be appriciated
Old Oct 30, 2012 | 03:54 PM
TLMNICK's Avatar
My advice is to check ALL the fuses. There is a fuse box inside the car, and one under the hood near the battery. Check ALL the fuses in them both. Chances are you'll find a dead one somewhere.
Old Oct 30, 2012 | 04:08 PM
Greeny's Avatar
¯\(°_o)/¯
the clock is likely dead....try getting one from a junkyard car...
If the cd player is factory, then it's just too damn old to worry about fixing it lol....get a aftermarket head unit and have it installed...
Old Oct 30, 2012 | 04:33 PM
VQ30DE-K's Avatar
check fuses, the one under the dash of the drivers side, on the chart is says "batt acces" battery accessories.
Old Oct 31, 2012 | 04:24 AM
ryandaiber's Avatar
i would check fuses for sure. i have 2 extra working clocks if you need one. i also just bought a 96 gle parts car for my 5spd swap. if you can think of anything else you may need let me know. just a little shipping charge or you can pick them up if your ever in the charleston area.
Old Oct 31, 2012 | 05:27 AM
nsnrider's Avatar
thats good advice there.
Old Oct 31, 2012 | 05:30 AM
stanltod's Avatar
Clock and CD player are known problems on our cars. Does the radio am/fm part and the display work? If so it's not a fuse. It's common for these cd decks to go into error mode where they won't read a CD or the mechanism inside falls. There was a recall on many of these head units back in the day that has long expired. Mine was replaced by dealer twice. Possible the previous owner had a replacement non stock deck in the car then swapped the non working factory deck back in to sell the car? Maybe didn't even hook it back up to power? As for clock these have terrible ground problems and gremlins like the Maxima in general. Mine resets all of the time and only works about half of the time. I just don't feel like tearing into the dash to fix or replace it.
Old Oct 31, 2012 | 09:06 AM
DennisMik's Avatar
I agree that the CD player/head unit is probably junk, especially if it is a Bose. The clock is probably repairable, they suffer from cold solder connections. But if you are not a fix it yourself person, then replace the clock.
Old Nov 1, 2012 | 07:13 AM
JAmerican's Avatar
My CD player also has an error message when I use it. I tried cleaning it with one of those CDs with a a brush on it. No luck. I just use the tape deck with my smartphone now! It's pretty clear with the BOSE surround sound. There is a way to add AUX to the stereo but it requires soldering and I believe if your CD doesn't work on some stereo units, the AUX hack won't work either.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
