1999 Nissan Maxima SE, guillotine by hood
Old Oct 31, 2012 | 08:33 PM
cham77's Avatar
If you own one you know what I am talking about. Who was the genius that decided to put the entire weight of the hood on shocks? Where is my friggin' steel bar prop? Was that "optional"? I just ordered some StrongArms for it, they have a lifetime guarantee. Anyway, just hope that guy got fired.
/rant
Old Oct 31, 2012 | 09:03 PM
DennisMik's Avatar
After several near concussions between both of my cars, I think I know what you are talking about. I installed Strongarms on both cars earlier this year, so I hope that will protect my head.
Old Nov 1, 2012 | 05:43 AM
Trini Boom's Avatar
Yes, we do understand what you mean but also realize that after 12+ years, those struts will fail at some point. Can't last forever but 12+ years is a long enough run if you ask me. I am pretty sure some people here still have their OEMs still going strong.
Old Nov 1, 2012 | 06:13 AM
GGENIUS's Avatar
what kind of dumbass puts the hood up to his car, held up by struts, and doesnt check to see what kind of shape the struts are in? at which point you put something under the hood until you replace them...
Old Nov 1, 2012 | 08:22 AM
isandres8884's Avatar
Old Nov 1, 2012 | 08:34 AM
asand1's Avatar
Broomstick in the trunk ftw.
Old Nov 1, 2012 | 08:44 AM
Maximeltman's Avatar
Axe handle...
Mine still go, but high winds sometimes overcomes them, then SLAM...
Old Nov 1, 2012 | 08:53 AM
Bassbreaker's Avatar
Originally Posted by Maximeltman
Axe handle...
This....mine were perfectly fine but a bit of wind will slam that thing down hard if you're not careful
Old Nov 1, 2012 | 09:03 AM
asand1's Avatar
I have thought about installing a wrecking yard prop rod from a Toyoduh or honduh.
Old Nov 1, 2012 | 09:35 AM
8000watts's Avatar
Vice grips for me
Old Nov 1, 2012 | 10:17 AM
saig's Avatar
'Guillotine by hood'
Perfect timing. Yesterday was Halloween. You did not need a costume, right? A headless zombie seems like a fit.
Just trying to lighten you up seeing your first post.
Old Nov 1, 2012 | 10:27 AM
GGENIUS's Avatar
Axe handle...
might be time to change
Old Nov 1, 2012 | 11:23 AM
asand1's Avatar
I lost my right middle fingernail to the hood while doing VC gaskets.
Old Nov 1, 2012 | 11:47 AM
cardana24's Avatar
Blown
Originally Posted by 8000watts
Vice grips for me
+1
I got a kick out of this thread because I knew exactly what you were talking about before opening the thread. Use vice gips like 8000watts said
Old Nov 1, 2012 | 12:02 PM
JvG's Avatar
JvG
Spend a little money and replace them with new ones. Mine were about 50 dollars at O'Reilys.
Until then a broomstick works, but not in windy areas. Vicegrips, yes.
Old Nov 1, 2012 | 12:25 PM
ryandaiber's Avatar
strongarms on amazon for $29
Old Nov 1, 2012 | 03:34 PM
FreshRichie's Avatar
my struts aren't functional at all haha, all bent up, doesn't hold it even slightly. i use a metal rod from a scrapyard that was used to hold up the hood on some other car
Old Nov 1, 2012 | 03:38 PM
ShocknAwe's Avatar
Never had this problem before but if I noticed mine were going downhill I certainly would not trust them, even less so on a windy day.
Old Nov 1, 2012 | 04:07 PM
kasso28's Avatar
I've been toying with the idea of removing the shocks completely and rigging up an actual hood prop. It would give a bit more working space too.
and to the guy that said its because they are 12+ years old, buy some new ones from an auto parts store and see how long they last...6 months to 1 year usually...
Old Nov 1, 2012 | 04:20 PM
Trini Boom's Avatar
I know the aftermarket ones don't last long....been through a few myself. The OEM ones are better but at $130/piece, people opt to not shell out that kind of money for this part.
Old Nov 2, 2012 | 07:22 AM
BigLou55's Avatar
you should be fine with those. I put some on my car 2 years ago and they still force the hood up, with no problem of holding it up.
Old Nov 2, 2012 | 07:57 AM
Dbird's Avatar
installed mine 4 year ago from autozone. Still holding up with no issues
Old Nov 2, 2012 | 08:07 AM
CallMeThatOneGuy's Avatar
+1 mine still do perfect in hot or cold. $30 each at advanced auto
Old Nov 2, 2012 | 10:02 AM
stanltod's Avatar
$3 hood prop from JY Toyo Camry ftw.
Old Nov 2, 2012 | 10:04 AM
tigersharkdude's Avatar
Still rocking a set of StrongArms off of Ebay for 4-5 years. Still work just as good as new
Old Nov 2, 2012 | 12:08 PM
mrbat's Avatar
Go ghetto and use a shock from a lambo door kit......**** will never fall, but then you'll have a hell of a time closing the hood lol
Sent from the batcave
Old Nov 2, 2012 | 12:12 PM
lilmoes4g63's Avatar
Ok looks like some home mechanic needs to write up a DIY for a how to install hood prop from whatever car to our maximas.LOL This thread is hilarious but real **** i had wind blow the hood down on my MK3 supra and man that thing slammed hard...Somebody PM me when they get that DIY done haha
Old Nov 2, 2012 | 07:07 PM
ct27gt's Avatar
Yes, because the first thing every maxima owner does when they pop their hood is check the hood struts. Shouldn't have to in the first place.
Hood prop has an infinite factor of safety and infinite life. Hood struts have neither. Almost always the simplest designs are the best. Nissan must have preferred head trauma over the 2 seconds it takes to lift a steel rod.
Old Nov 2, 2012 | 07:42 PM
GGENIUS's Avatar
when in the hell did i say anything like that? not first thing, but anyone working on a car i know, when they open a hood that obviously isnt held open by a rod, they open the hood, see how it stays on its own, and gives it a little help to push to see if it will fall under any stress. the first time a car slams on you you should learn your lesson.
Old Nov 3, 2012 | 05:10 AM
Originally Posted by ggenius
when in the hell did i say anything like that? Not first thing, but anyone working on a car i know, when they open a hood that obviously isnt held open by a rod, they open the hood, see how it stays on its own, and gives it a little help to push to see if it will fall under any stress. The first time a car slams on you you should learn your lesson.
qft
Old Nov 3, 2012 | 05:59 AM
max ride 41's Avatar
thread fail. its called common sense, what do you want: 1. a motor that holds up under extreme duress, or 2. hood struts that hold up forever? c'mon now, stop bichin...
Old Nov 3, 2012 | 08:23 AM
GGENIUS's Avatar
trust me its a lot worse than getting hit on the head or the hand, when youre working on someone elses car and their struts are only at 60% strength, and their hood slams down on a couple tools you have under the hood. completely TWEEKING their hood which is very hard to get back to normal.
Old Nov 3, 2012 | 08:26 AM
Hood struts mean there's no prop that is in the way when working on your car.... No complaints from me I'm constantly under my hood. If you dislike pistons for some reason, get $2 prop and install/enjoy. good day
/thread
Old Nov 3, 2012 | 08:28 AM
GGENIUS's Avatar
/thread
im so used to struts. half the time when i actually get a toyota with a prop rod, i go to close the hood without moving the rod, because im so accustomed to struts.
Old Nov 3, 2012 | 09:56 AM
ShocknAwe's Avatar
Ive never in my life left tools in my engine bay
Old Nov 3, 2012 | 12:31 PM
i have one of these, just in case. they work great...http://www.ebay.com/itm/Universal-Ho...4ff6c1&vxp=mtr
Old Nov 3, 2012 | 01:36 PM
Kuhn_man's Avatar
i bought new ones from autozone and it doesnt matter how strong the wind is it wont go down. common sence if your shock is bad replace it and the problem goes away. my olds ones held up but not in wind my new ones i dont even worry no matter how windy it is out
Old Nov 3, 2012 | 01:47 PM
Kuhn_man's Avatar
are you really that stupid? do you even work on cars. a prop doesnt have infinite safety and life, they bend and they fail ive seen it my fair share of times.
you must be the type of guy who gets in your car and drives down the road with this flat *** tire because you dont check anything before you use it, then b1tch about how tires still take air and a solid rubber tire wouldnt have that problem.
get real buddy things wear out that why we fix them, the struts when new were more than strong enough to hold up the hood, im sure nissan figured if people were dumb enough to go under the hood with bad struts they deserved to be smacked in the head.
Old Nov 3, 2012 | 02:15 PM
here's the problem kuhn Join Date: Oct 2012 stupid is as stupid does
Old Nov 3, 2012 | 03:42 PM
GGENIUS's Avatar
when youre doin a bunch of work under the hood, you dont rest tool all over the inside of the bay, for when you know youll need them again soon? in precise grooves of course.
