Clear / Red Taillights
Old Jan 9, 2002 | 09:38 PM
boosted95's Avatar
Where do i get the half red half clear taillights from. i want them desperately. just got my MAX.
Old Jan 9, 2002 | 09:42 PM
nigelcmf's Avatar
Not sure how to linkn threads here...but you can try this guy. Don't know if he still has them.
http://209.185.240.250/cgi-bin/linkr...goto%3dnewpost
Old Jan 9, 2002 | 09:45 PM
nigelcmf's Avatar
Sorry that didn't work....do a search on red/clears in the group deals section. It is by pocketrocket....I should figure this link stuff out...anyone help?
ny96max's Avatar
.... check the group deal forums and see if you can get David's e-mail adress. If your lucky he will make them for you too!
mine are 3 yrs old and still look like the day i got them from him.
Old Jan 9, 2002 | 09:46 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Clear / Red Taillights
most people make them... here are directions from www.maximadriver.com
Rear Tail Light Conversion for 1997-1999 Maximas
WARNING: These are JUST directions. I am NOT liable if you mess up your tail lights. Use common sense when attempting this or ANY mod. Always use caution when it comes tools that use electricity. WEAR PROTECTIVE CLOTHING!
If you'd rather BUY this mod than make it, i recommend GREG and his rear tail lights. you can buy them here.
NOTE: This modification WILL NOT WORK for 1995/96 Maximas. This is because the tail lights are a single unit. The Amber in the 95/96 model years is physically attached to the red portion. It's one piece that can not be separated. The only other way to make the red/clear look is to buy clear tail lights and paint them red. David L in New York does this conversion for the 95/96 maximas for a cost (~$175 shipped). Please email him directly if you're interested. Just tell him that i sent you.
Tools needed: 8mm deep socket, Screw driver, Heat gun, some good gloves, several layers of foil or some sort of metal for protecting the lense from heat, a 2' x 2' piece of flouresent light covers (that you get at any hard ware store), a sharp knife, flashlight, and if you want, a friend to help.
1. Start by removing the carpeted panels in the trunk, that are around the rear lights. Pop off those annoying clips and keep them in a safe place.
2. Remove and unplug all the wires and light bulb connections that are attached to the rear lights.
3. Pry off the two plastic wire holders that are on the back of two 8 mm bolts. These clips hold the wires in place, just pop them OFF.
4. Using the 8mm deep socket, remove the 4 nuts that secure the housing.. two up top, two on the bottom, keep the nuts in a safe place.
5. Now, this is a bit hard now.. push the taillights like you've never pushed before.. from the INSIDE of the trunk OUTWARD.. the lens housing will slowly, but surely come off of the car. Don't worry about the back goo that's attached to it. It's there for sealing purposes and will RESEAL itself once you put the housing back in when you're done.. Cut the goo with a knife so you can free the housing from the car. The goo will stain your clothes, so WATCH OUT!
6. Next, look behind the housing there will be 5 small screws holding the lense down to the housing as well as some glue. Remove the screws..
7. Using the heat gun now, heat around the edge of the housing taking a piece of thin metal and cover up whatever you don't want to heat up like the edge of the lense and the rubber seal. Heat in sweeping motions, don't concentrate on one part for too long.
8. Continue heating evenly. If you get any king of warping, STOP. Go around the whole lense housing until everything is evenly warm.
9. The housing should be hot enough for the glue to release the lens.. Slowly, start to pull the lense away from the housing. Use caution. DON'T use extreme force, if the lense won't move, apply more heat.
10. Once the two pieces are seperated, remove the amber lense piece
11. Using the amber lense piece as a template, cut out your clear pieces from the flourescent lighting cover. Make sure the edges are cut even and straight. If you'd like, you can cut another lense piece for the other side, but besure to flip the amber piece over to make LEFT and RIGHT side pieces. After you have cut out the clear pieces, slide it back into the lense housing.
12. Heat the housing black piece again and place the lense back into the housing.. you're almost done!!!
13. Once the lense is flush with the housing, replace the 5 mini screws into the housing. Don't over tighten.
14. Push the lense housing back into the car. By retightening the 8mm bolts, the lense housing will reseal with the black goo. No need to over tighten the 8mm bolts.
15. Re-connect the light bulbs and the wiring. Please, don't forget to get 1156 ORANGE blubs so that the clear part will flash orange. Put back the two plastic wire holders that are on the back of two 8 mm bolts.
16. Repeat steps 1-15 for the other lense
17. TADA. you're done. Sit back, drink some beer. rejoice.
Old Jan 9, 2002 | 09:49 PM
guitaraus's Avatar
Re: Re: Clear / Red Taillights
pssst....bags....wrong how2....
Old Jan 9, 2002 | 09:50 PM
ny96max's Avatar
atleast he was helpin out, lol
Old Jan 9, 2002 | 10:14 PM
Bags's Avatar
Re: Re: Re: Clear / Red Taillights
yep your correct thanks
bags
Old Jan 9, 2002 | 10:21 PM
zzeeoo's Avatar
Depends on what year max you have.
www.custommaxima.com has them for 97-99.
ZZeeOO
Old Jan 9, 2002 | 10:45 PM
nigelcmf's Avatar
Yup...sorry...Pocketrocket had a grp deal b4 xmas...too bad you missed out. Don't try to clear them out yourself. it does not work on the 95-96. Only 97-99!
Unfortunately custommaxima doesn't have them either, I checked that out for you. only have 97-99s.
Old Jan 10, 2002 | 02:54 AM
Sprint's Avatar
you have a better chance of seeing the lord
Old Jan 10, 2002 | 03:09 AM
Nismo's Avatar
which, in this case, many of us had
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
