Need Help
Need Help
I have reset my ECU two weeks ago with a code 5 long 12 short. Yesterday I did the same thing. I tried checking the code but there is no option for 12 short blinks. It seems that this is happening everytime we have a change in the temp outside. It started happening after the y-pipe and exhaust install.
Re: Need Help
its in there
Re: Re: Need Help
Re: Re: Re: Need Help
Thanks! I guess the sensor need replacing after all. It's weird though because I have check it before I put it back in the greddy exhaust and it seems fine. Do you think it's possible that the y-pipe is causing this or the random cat?
Originally posted by SprintMax
are you following me?
Actually I realized right after I posted you got in there right before me. Couldnt have been much since we posted the same minute. But the question is am I following you or are you doing everything right before I do, which would make you pre-following me.
SuDZ
Re: Re: Re: Re: Need Help
you might have damaged it during removal or replacement.. just keep in mind it has no function on the performance of the car..
