Should I buy it?
Old Dec 27, 2012 | 04:32 PM
Spencer5556's Avatar
Should I buy it?
A guy on CL is selling a 4th gen max with 176k for 1700
I talked him down to 1200
He says it has a rough idle, he says the RPMS will rise to 800 them drop to about 500 and shake like it is gunna die.
My first thought is dirty fuel filter or bad fuel pump. What do you guys think? Should I buy it to resell?
Old Dec 27, 2012 | 04:41 PM
mwatters's Avatar
seems like a good deal for a maxima!
Old Dec 27, 2012 | 05:39 PM
asand1's Avatar
Sounds like iacv. Buy it.
Old Dec 27, 2012 | 05:42 PM
LazYRaCeR's Avatar
if it's something easy and cheap to fix that you can do yourself, then I say buy it, fix it, and sell it if you can make a couple of grand or so.
Old Dec 27, 2012 | 06:00 PM
locknuts27's Avatar
CEL on? If so pull codes, then decide if it's worth buying it? I bought 2002 Maxima that needs some real love for 1500 dollars. She is coming along...
Old Dec 27, 2012 | 08:17 PM
AllMaxxedOut's Avatar
Check carfax and check for rusting. Definitely pull codes and assuming that is good then go for it.
Old Dec 27, 2012 | 09:03 PM
T_Behr904's Avatar
For that price i'd buy it. Worse case scenario, if someone hits you and your car is totaled, you'll probably get somewhere in the ballpark of $3,500 for it, so you'll be coming out ahead.
Fp3's Avatar
Fp3
Do you need a carfax? i have like 4 reports left that I won't use and I can send you the results from it, I'd hate to see the extra reports go to waste
Old Dec 27, 2012 | 11:21 PM
max ride 41's Avatar
dude, seriously if your that close go check it out in person. we don't need another " should i buy it?" thread in here. c'mon now, you know there's issues with it, it's old, could be anything.
Old Dec 27, 2012 | 11:23 PM
hunh??? 3,500.00???? where did you come up with that price?? probably be lucky to get 1,500 from what i've seen.
Old Dec 28, 2012 | 06:17 AM
I'm going to look at it tomorrow. Ill give an update and most likely have a few questions. They said it sometimes has trouble starting.
Old Dec 28, 2012 | 09:45 AM
Amerikaner83's Avatar
Link to the cl ad, spencer?
Old Dec 28, 2012 | 09:52 AM
Fatboy98maxima's Avatar
1200 is a very good price go for it at worst u will have to put in like 300 bucks to fix issue so that is 1500 not bad
Old Dec 28, 2012 | 10:20 AM
nsnrider's Avatar
you didn't mention what year it was? if its a 95, $1200 is about retail with that many miles and I would stay away from it with a CEL on.
If its a 99, the price is fair even with a cel on.
good luck, decide if it makes sense to you.
Old Dec 28, 2012 | 10:30 AM
really... at worst? what if the timing is off? Timing chain is way more than a 300 dollar job.
I found the CL ad:
http://seattle.craigslist.org/sno/cto/3503435768.html
I've got our 1997 Nissan Maxima with 178k miles that runs but idles rough and sometimes has trouble starting. We are moving and do not have time to fix it but it would be a great car once it is fixed up. Very clean and very nice interior. Has a very nice Bose sound system, leather seats, power windows, automatic transmission. Would also be great for a parts-car. $1700 OBO
Doesn't look bad...but not starting on a 97 could be CPS / CKPS, fuel filter...IACV, vac leak somewhere...or even blown engine.
I'd be worried about the auto trans with 180K on the clock...but that's just me, based on the no-start.
Old Dec 28, 2012 | 10:49 AM
I found the CL ad:
Update: they said they just replaced the timing chain tensioner, and a little bit after, they problem came up.
Old Dec 28, 2012 | 10:51 AM
convenient.
Timing's probably off.
Old Dec 28, 2012 | 02:09 PM
convenient.
Easy fix? Or would I need to remove the timing chain?
Old Dec 28, 2012 | 02:14 PM
well it "runs"...so
if timing was completely off it wouldn't even run.
The thing with "mechanic specials" on Craigslist is that if it doesn't run properly, it's usually never a simple fix. If it WAS a simple fix, they'd be the ones doing it.
Buyer beware...and be sure to get a vehicle inspection.
Old Dec 28, 2012 | 02:57 PM
well it "runs"...so
The only reason I thought it would be easy was because it is a 19 year old girl who seems to know very little about cars.
Old Dec 28, 2012 | 03:22 PM
bring a mechanic friend with you
Old Dec 28, 2012 | 04:53 PM
Max139617's Avatar
This. to the OP try to get the car a lot cheaper, im talking sub $1,000. Around the $500-$800 range. OH only if the rest of the car is good enough (no dings, dents,etc.)
If the seller is desperate than you might just get a good deal. And if after changing the ckpos, IACV, coipacks, starter, nothing happens, you could just 3.5 swap/5speed swap it. Or you could part it out.
Old Dec 29, 2012 | 09:45 AM
maxinout93's Avatar
sounds like a decent deal, i would grab it before someone else does, sounds like it may need a ects or a small amount of work, little parts u can pick up and the local junk yard and install yourself. i bought my 95 with a ton of issues, rad leaking, pulling to one side, shutting. off ect and it had 217k on the clock. so i would get it.
Old Dec 29, 2012 | 10:04 AM
T_Behr904's Avatar
Insurance companies gather selling prices of similar cars in the area. They usually throw out the lowest and highest priced ones, and average the rest together. So, if there are 8 Maxima's like his with similar mileage in a 100 mile radius, and they average out to be $3,500, that's what he'll get. It's called fair market value, since they have to give him the replacement cost for the car. Let's say they average less, maybe $2,500... They won't cut him a check for $1,500 because that is a grand less than what he would need to purchase the same car.
It all depends on the area where you live. Around here, 4th gen Maxima's sell between $3,500 and $4,500, unless it is a basket case.
Old Dec 31, 2012 | 04:55 PM
Update: went and took a look at the car, the timing chain was slapping pretty hard, I decided it wasn't worth the risk to make a couple hundred. If I am going to do anything with a timing chain, ill fix the leak in my timing chain cover. Thanks for everyone's thought and opinions!
Old Dec 31, 2012 | 05:10 PM
good choice. i've had a timing rattle in my engine for almost 8 years, yes 8. as long as it quiets down after warm up, your fine. keep oil fresh and just keep an obd 2 reader handy and all your fluids fresh. i think people don't realize the importance of viscosity, and breakdown. that's when $hit fails and you find yourself at the roadside cursing at the car.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
