electrical problems
electrical problems
hi
about a month ago my friend bough this 95 maxima 3.0 auto , and about 2 weeks ago she is having some electricl problem , here are the symptoms
it wont crank , something u have to jiggle the key to crank it , also when you first turn the key the wipers come on and you cant shut them off with the wiper switch , then after it cranks it runs for a few seconds and then it dies , in order to keep it running you have to keep your foot in the gas to keep it reving otherwise it will die
Couple of problems here. First, start by replacing the ignition switch to correct key jiggling. Second for wipers, if the arm is set to be off, you may need to replace the switch but will not rule that out yet. If you have to keep your foot in the gas for a few seconds and then let it go for it to stay on, you will need to clean out TB, IACV first. If it still occurs, replace the FPR.
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
