help with code 1005 egrc
Old Mar 18, 2013 | 01:14 PM
2THEMAX98's Avatar
i pulled a code 10 long,5 short pulses which from pmohr's guide is the egrc solenoid valve. what should i be checking first? will cleaning the egr tube have an effect on this code or will it be strictly the solenoid or valve? any help or tips is appreciated
Old Mar 18, 2013 | 01:52 PM
BlackThornDemon's Avatar
Had the same problem. Replace the solenoid. Its the green thing with 3 hoses and 1 electrical connector. Its bolted on underneath the unit.
Also, search. This has been covered 100+ times.
Old Mar 19, 2013 | 11:43 AM
2THEMAX98's Avatar
i searched but i still had a question before i took the car back to the mechanic, i had 4 codes but now im down to one. so i wanted to know if the egr tube being blocked would create check engine light or if it would only be the solenoid or the valve itself causing it. thanks for your help though
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
