Stripped bolt from clutch to flywheel - Help?
Old Apr 11, 2013 | 06:34 PM
Max_Gator's Avatar
Replacing my clutch.
Unfortunately, I stripped one of the bolts from the clutch to the flywheel. I was being extremely careful, using torque wrench and torquing to spec. Oh well. It is not badly stripped since I stopped immediately.
Obviously, the most conservative fix is to replace the flywheel.
However, I'm wondering if I could go without one bolt out of the three bolt set - middle if it matters. And if so, I'm guessing I should completely remove the bolt to prevent it from coming loose.
The only other thing I can think to do is to threadlock it down. FSM doesn't call for treadlock on those bolts.
Any experienced suggestions would be very much appreciated.
Thanks.
Old Apr 11, 2013 | 06:50 PM
njmaxseltd's Avatar
One missing bolt will throw the balance off quite a bit.
Drill, tap, heli-coil, fix it right, you don't want to open it up again.
Old Apr 11, 2013 | 06:59 PM
Max_Gator's Avatar
Thanks!
Old Apr 13, 2013 | 07:15 PM
OneFastStanza's Avatar
I second what njmaxseltd said. You want to do it right from the get go though.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
