quick question about my RACK ;)
Old Apr 29, 2013 | 08:43 AM
DIASISS OF JASSICS.COM's Avatar
where is the drain plug on my 97 Maxima? its time for a fresh change.
Old Apr 29, 2013 | 09:30 AM
asand1's Avatar
There is no drain plug for power steering.
Old Apr 29, 2013 | 09:38 AM
asand1's Avatar
Do a search for PS flush. Replace with dexron III.
Old Apr 29, 2013 | 10:26 AM
whats a PS flush? and why no drain plug?
i was thinking about unscewing a line,and starting it up to run all the fluid out. good idea?,bad idea?
Old Apr 29, 2013 | 10:34 AM
Fakie J Farkerton's Avatar
http://forums.maxima.org/fluids-lubr...uld-i-use.html
Old Apr 29, 2013 | 10:39 AM
Originally Posted by Fakie J Farkerton
thank you all
Old Apr 29, 2013 | 11:13 AM
asand1's Avatar
whats a PS flush?
SEARCH
Iv'e never seen a drain plug on any PS system
NO. Do not run the pump dry. Add some and start for a second or two, then repeat.
Originally Posted by Curt Deiner
What I did with a helper was pull the ps return line from the reservoir, drain, cap the nipple on the reservoir, and fill with Mobil 1 ATF, return line directed to a bucket. Helper starts car and turns wheel back and forth while I keep adding ATF to reservoir. You may need helper to stop car so you can keep up. Don't let it run dry, air in the system can create a frothy strawberry milkshake mess, and low fluid level once the bubbles come out.
I did mine this way by myself. Duct tape the return line into a 2 liter soda bottle. Fill reservoir and start. shut off before reservoir goes empty
(~3 seconds). I used just less than 2 quarts of Chevron MD-3 ATF.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
mikeg75
Nov 30, 2015 05:12 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
