my fan blower selector switch only works on hi.
Old Jan 13, 2002 | 08:31 PM
bluman3's Avatar
do i need another selector switch. also the chime when you leave the keys in the ignition or your lights on when the door is open doesn't work. please help.
Old Jan 13, 2002 | 08:32 PM
bluman3's Avatar
i checked all of the fuses.
Old Jan 13, 2002 | 08:58 PM
global_threat's Avatar
try doing a search? this has been covered before...I don't know about your door chime, but the resistor in the fan switch is broken...
http://forums.maxima.org/showthread....ght=fan+switch
Old Oct 29, 2007 | 07:36 AM
Murph_NH's Avatar
Any update on this issue? Seems the blower switch on my '98 only works on high - low low/med, and med are completely dead. Same results for AC or heat. No climate control - just a 4 position ****.
Thanks!
Old Oct 29, 2007 | 08:08 AM
bluman3's Avatar
Thanks!
they resistor board had to be replaced. it was about 25 dollars from the dealer. do a search on the replacement of the board it is very easy. i replaced it a while back so i don't remember the steps
Old Oct 29, 2007 | 08:11 AM
tvis's Avatar
fixed link
http://forums.maxima.org/showthread.php?t=61329
and I was gonna say the same thing as far as it being the resistor pack. My Jeep has had the same problem.
Old Oct 29, 2007 | 08:29 AM
BORQUA79's Avatar
nycmaximas member
I had the same issues... It happened to be my resistor for the fan located under the passenger glove box. Just get one from the parts store and replace, then your done. Follow the link that was posted earlier.
good luck
jerrod99_se-l
Aug 27, 2015 08:27 PM
98nismomax
Aug 13, 2015 12:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
