Radiator coolant
Old May 13, 2013 | 07:39 PM
Erin_Maxi's Avatar
Radiator coolant
How many gallons of coolant does it take to fill a 97 maxima radiator
Old May 13, 2013 | 08:41 PM
I believe between 1.25 and 1.5 gallons to fill the radiator. Don't forget that 50% of that, give or take, should be distilled water. Check out the Fluids forum for future fluid related q's. Welcome to the Org.
Old May 13, 2013 | 09:19 PM
DennisMik's Avatar
The total cooling system that includes the engine, radiator, heater core, hoses and anything else that has water in it, takes 9 quarts (2.25 gallons). If all you did was drain/replace the radiator, probably half a gallon. The engine will remain almost full unless you remove the drain plugs in the engine block.
Sounds like you need a service manual. You can get one here and look up the info in section MA, page 9.
http://boredmder.com/FSMs/Nissan/Maxima/1997/
Old May 13, 2013 | 09:25 PM
Coincidentally, I just filled my Griffin aluminum radiator yesterday, and it took 1.75 gallons. So I figure the OEM radiator would be 1.25 to 1.5 gallons...
Old May 19, 2013 | 08:10 AM
Erin_Maxi's Avatar
Thx you guys
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
captchaos
Mar 15, 2016 12:18 PM
Hdnseek
Sep 9, 2015 05:55 AM
