when do you know if timing belt is bad?
Old Jan 15, 2002 | 06:22 AM
Fish254's Avatar
I was wondering does any one know when the timing belt goes bad what does the car start doing and did any one change is on there car and how much will it cost?
Old Jan 15, 2002 | 06:24 AM
1Phat Max's Avatar
Re: when do you know if timing belt is bad?
If you have 95 and up yr. Max, then we dont have timing belt, we have timing chain which does not need to be replaced unless there is major damage to it. but I heard that it can get loose and you have to get it tightened. what are the problems you are having?
Old Jan 15, 2002 | 06:31 AM
Bags's Avatar
VG Ridah's Biatch Hoe
looking at your profile you have a 1996 maxima. So 1phat max is right on the money. You have a timing chain.
If it breaks loose your gonna have many problems
jiaxima96's Avatar
If you only want to know what the timing belted car does just before time belt breaks, I had one time experience on my 86 Sentra. It didn't feel it doing antthing abnormal, just suddenly broke. Tried starting the engine again. It just turned but never started, like running out of gas...
Old Jan 15, 2002 | 06:41 AM
Fish254's Avatar
when the engin is cold it tends to vibrate alot and latly when i warm up my car the first stop that i make the rmps drop and the car vibrates i put the car in neutral and and then drive again the car goes back to noraml?
Old Jan 15, 2002 | 06:47 AM
95emeraldgxe's Avatar
replacing the timing chain doesnt cost too much
Old Jan 15, 2002 | 07:02 AM
mzmtg's Avatar
Minister of Silly Walks
ha!
Who told you that?
It's a pretty major operation on a VQ...
Old Jan 15, 2002 | 07:15 AM
JeepRage's Avatar
Originally posted by mzmtg
ha!
Who told you that?
no kidding... take apart engine... big $$
Old Jan 15, 2002 | 07:28 AM
njmaxseltd's Avatar
Clean your throttle body.
Old Jan 15, 2002 | 07:37 AM
Bags's Avatar
Really? Look at a Factory Service Manual and the come back and tell me that
Old Jan 15, 2002 | 07:53 AM
Dasyce's Avatar
when i start my car.. i hear a metalic noise.. like that of a chain .. but its not loud.. the sound is new.. not sure if the timing chain is touching something... it's only got 38k on her....
Old Jan 15, 2002 | 08:25 AM
NISMO808's Avatar
I agree. I had those symptoms too. After cleaning the throttle body the rough idle went away.
Old Jan 15, 2002 | 10:11 AM
Fish254's Avatar
so if i clean my throttle body the problem will end?
Old Jan 15, 2002 | 10:26 AM
Maxilicious's Avatar
Try around $1,000 and you may as well replace your water pump while you have everything apart. In the manual there is no maintenece window for the TC so it should last forever
Bags's Avatar
There is not one person here that can say yes. But it will not hurt, and it might solve it. If you do clean it... I would check the idle adjustment screw as well
Old Jan 15, 2002 | 12:59 PM
NISMO808's Avatar
There should be a red dot on the idle adjustment **** to help you know where it should be set. There's another **** forget what it's called but it raises your rpms when you initially let off the gas and then it begins to drop. I'll find out what that **** is called and then post again. But maybe someone else knows the technical details of how that works. My mechanic adjusted mine for me when I told him about my low idle shuddering problem.
Old Jan 15, 2002 | 04:17 PM
kmax's Avatar
Agree ....
I have this occasional idle problem also. The idle drops down to about 525 in Drive. I cleaned the TB and it didn't help. But, it did fix the cold start problem. My next step was a PCV (unlikely) and then clean the Idle Air Control Valve (guessing). Now I'm waiting for my Max to get out of the shop after being stolen and recovered.
Cleaning the TB is easy and worth a shot.
Old Jan 16, 2002 | 12:08 PM
Tubbed'65's Avatar
doesn't sound like a timing issue, follow everyone elses advice with the throttle stuff. Timing chains are pretty reliable, but i've broken more of those then i have belts, however, i replaced belts as required wear chains just go till they decided to snap. Under normal driving conditions chains do just fine, the motors that i've built myself in the past though, i broken them like dental floss. When a belt starts to stretch with age, your timing will be affected, the engine won't seem as peppy, this also happens with chains. I've snapped a belt on my old mazda truck and whoever said they were'nt hard to change is really full of it. I did mine and it took me the better part of a day, i'd say atleast 500 at a shop probably more with todays ludicrous maintenace costs. I do everything myself though and haven't seen a mechanic in a long time.
Old Jan 16, 2002 | 01:30 PM
jayanth's Avatar
timing chain
your timing chain is maintenance free .. should last as long as the engine lasts.., it does have a tensioner which needs to be tightened say after a 100,000.If you hear noise or vibration when the engine is cold.. it's the timing chain for sure.It should disappear when the engine warms up.
also, u can use 10W-30 oil to reduce this noise.. take care to warm your engine sufficiently before you rev up.
Cleaning the throttle body may help...but i don't know how?
take care,
jay
Old Jan 19, 2002 | 08:30 AM
Fish254's Avatar
how can i tighten the timing belt is it a hard job or should the mechanic do it?
Old Jan 19, 2002 | 08:43 AM
theblue's Avatar
dude.... clean your throttlebody... it costs about $2.00 then see if it clears up. I doubt there is anything wrong with your chain.
Old Jan 19, 2002 | 09:08 AM
sorry to say that your question isnt xactly legit since the maxima doesn even have one
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
FlaMark
25
Aug 28, 2015 10:15 AM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
