Maxima A32 stall on LPG while driving
Old Jul 27, 2013 | 05:28 AM
Grbo's Avatar
Hi guys!
Urgent help if someone has experience with LPG.
I have changed spark plugs and coils on my maxima 1996 and it's not stuttering any more, but one problem still appears.
When I am on LPG and slowing down or "gliding?" down the hill, occasionally car stalls. Before it does that, revs are jumping from 300-1000 (when slowing down) and in some point, valve cuts of and car turns of in driving (not a pleasant feeling at all). Also, when I am starting up a car, if i don't depress pedal a little bit, car will stall also as soon as gas valve opens.
As everything else when running on lpg is almost perfect, i reckon that it needs just a little tuning by adjusting one of 3 screws (shown on pictures). What I have find out is that on inlet line is "power" valve, and on converter one is for mixture and other is for sensitivity (didn't figure out which one is for what (1. is smaller and without spring, 2. is bigger and with spring).
Old Jul 27, 2013 | 04:51 PM
Quickywd01's Avatar
No one uses that here, not like europe.
Old Jul 28, 2013 | 12:43 AM
Grbo's Avatar
He he, or like in Australia!
No worries. I've found on other lpg forums that most likely it would be the air flow speed when car is driving above 50 or 60 km/h and when you remove foot from pedal or put it in neutral that creates difference in air pressure and that mess up gas mixture . One solution is to turn the inlet manifold in opposite direction of driving (backward).
My question is: what would happened if i just remove that plastic inlet pipe that goes to air filter box? would i loose power on higher revs or on higher speed?
P.S. it has two air inlet ends, one pointing forward and one down to the ground, at 90 degrees.
Cheers
Old Jul 28, 2013 | 01:51 AM
Climaxx's Avatar
Wow... Y'all's a32's are set up much differently. Lol
Old Jul 28, 2013 | 09:21 AM
schmellyfart's Avatar
Cheers
The hose coming off of the valve cover should be attached between the throttle body and the MAF.
His is just a little different because he had an LPG conversion/injection installed.
Old Jul 28, 2013 | 09:36 AM
Climaxx's Avatar
Compressor lines as well.
Old Jul 28, 2013 | 10:10 AM
I figured it was due to the LPG conversion, but looking at other Cefiro engine bays it appears stock.
Old Aug 3, 2013 | 03:53 AM
Grbo's Avatar
Hi guys.
I need a simple advice or an idea. After testing and tuning my car on lpg, seems that ram air effect was responsible for stalling while slowing down or braking. Find out that after removing a snorkel.
Now, it has very significant lack of power and response (warm air i reckon).
I would like to return snorkel back but i have an idea to reduce that ram effect somehow.
My idea is to put something in front of the inlet hole (few cm) so that air doesn't go directly into a snorkel (sticky dense foam or dense wire or plastic mesh).
They solve that usually by installing a balance pipe between snorkl i think and vapourizer, but i that's my backup plan (more work and more money).
Any ideas or advice?
Cheers
kjlouis
Nov 24, 2018 06:09 AM
schmellyfart
Sep 25, 2015 04:47 PM
julian888
Aug 6, 2015 04:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
yat70458
Aug 3, 2015 01:16 PM
