Parking LIghts
Old Jan 15, 2002 | 01:05 PM
MastaShimz's Avatar
Parking LIghts
I want to put in Blue bulubs but i cant get to the lights.....LIke i see them and i can touch them but there isnt enought space to pull the light out of the housing........Is there anyway to take off the parking lights?????????
Old Jan 15, 2002 | 01:06 PM
Sprint's Avatar
lights by the headlights or lights on the bumper?
Old Jan 15, 2002 | 02:22 PM
MastaShimz's Avatar
Lights by the headlights..........
Old Jan 15, 2002 | 02:39 PM
krzymax's Avatar
Maxima owner since 2000
open your hood. there is a screw right next to the housing. after removing the screw, pull as hard as you can on the whole housing to get it out. it is a ball in socket so it might take a little muscle to get it out.
Old Jan 15, 2002 | 02:40 PM
araffio's Avatar
Open the hood and locate the small plastic piece connected to the clearance lamp that is screwed to the frame of the car. Remove this screw and pull the entire housing out, its only held in by pressure fittings. Once its out, change the bulb and then put the housing back in. If you can't figure this out, then check in the owner's manual for instructions. Its simple...
Old Jan 15, 2002 | 02:55 PM
MastaShimz's Avatar
the drivers side came out with out a problem.........But the passenger side isnt comming out at all....it seems like its screwed in sumwhere.........
Old Jan 15, 2002 | 02:57 PM
Sprint's Avatar
its held in by a rivet on the lower portion.. use a flat head screw driver and pry it out
Old Jan 15, 2002 | 04:06 PM
95emeraldgxe's Avatar
time to whip out the WD-40
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
cruce91
Sep 20, 2015 10:23 AM
markevans999
Sep 10, 2015 04:29 PM
