EMERGENCY: CALLING ALL 4TH GEN EXPERTS. CKPS issue
Tonight I was getting on the highway and i stepped on the gas and I heard and almost felt a grinding noise (cannot find proper word for noise description) and my check engine light came on. Because I was delivering I got back to the shop and I came out to start up my car and it would crank all day and not start. So called up a buddy to bring his scan tool so I can see the code, reset it and hopefully start up the car and deal with the issue tomorrow. My heart sank when the two codes were crankshaft position sensor and a pending sensor code. I popped the hood and looked around and my drive belt was torn in half pretty much (must have lost the other half on the highway) but i could see the frayed edge.
Now here's a twist: I have had that same drive belt and tensioner for it replaced within in the last six months so i'm assuming something made this happen which is what i'm troubleshooting. Could the sensor have been going bad and causing me to have belt problems or could possibly one of the individual pulley components be causing my timing to be off. I had a nissan tech who works at the dealership replace the belts and i had to go back and get them tightened because it started to squeal again! That factor alone tells me something in that loop is causing the belts to go bad and the timing to be off by just enough to ruin it. I'm stuck in the position of either replacing the belt, and the sensor myself with a mechanic friend, or just letting a shop look at it and work on it. I welcome expert advice and input and yes there's other threads in regards with an issue like this but I am reaching out for advice so telling me to search is unproductive because I already did plenty o it. Thanks in advance |
Your DTC and belt shredding issues are two totally separate issues.
Originally Posted by Climaxx
(Post 8836516)
Is your crankshaft pulley doing the wobble?
I've heard of the power steering belt getting chewed up because of this when it gets real bad. |
Replace the sensor and O-ring and make sure you tighten the tensioner pulley correctly. If its making a squeal then it's still loose man.
I think I'm just gonna sit back and let the shop take care of this problem, because it has been an occuring issue and I don't want to screw up fixing the issue. Thanks for the replies
Originally Posted by BostonBarrett475
(Post 8836535)
What was the CPS code?
There are 2 crank position sensors. CPS REF is located just above the crank pully, CPS POS is located on the transmission bell housing and looks at the flywheel. Being the belt shredded, you might have a crank pully issue which could have also destroyed CPS REF. |
Crank pulley is wobbleing and destroying your belts, mine ate my belts twice before i bought a new One.
Originally Posted by njmaxseltd
(Post 8836585)
(Post 8836585)
Originally Posted by Fauken
(Post 8836647)
This I need to work on that I guess. |
Originally Posted by Fakie J Farkerton
(Post 8836657)
My short answers/questions always get ignored. :sadpace:
© 2024 MH Sub I, LLC dba Internet Brands
