Door panel removal/front speaker install?
Old Aug 11, 2013 | 02:24 PM
ProV1's Avatar
I searched & "how to" section has a page but none of the pics load. Does anyone have a link to a proper page with some pics? What tools do I need to remove & install new front door speakers - I do not have any harnesses.
Removing the stockers and putting in JL Audio TR650s
Old Aug 11, 2013 | 03:04 PM
Aflion's Avatar
Remove the door handle cup by the handle by putting a flat blade in at the top and pressing down on the little tab. Take the door cup on the armrest out by prying the screw cover off, then take a phillips screwdriver and take that screw out, then the cup, then the two screws on the bottom of the door panel. After that, use a flat blade to pry the plastic clips on the door panel away from the door itself. Theyre all around the panel. After that, pry the side mirror cover off that allows the screws to be seen from inside the car, then lift the door panel off and unclip the power window/door lock switch, trunk release switch on drivers side if you have it, and the courtesy light if you want to. Then just replace the speakers.
Posted from Maxima.org App for Android
Old Aug 11, 2013 | 03:05 PM
Aflion's Avatar
Just do all of that. If you need pictures, you probably don't need to be doing it yourself. Lol.
Old Aug 11, 2013 | 03:56 PM
jholley's Avatar
This How To for removing door handles shows how to simply remove the door panels
how-removing-installing-exterior-door-handles-picture-intensive
Old Aug 11, 2013 | 05:39 PM
ProV1x's Avatar
awesome. helps a lot!
what is the size of OEM front speakers? 6.5"?
Old Aug 11, 2013 | 05:52 PM
maxfever1987's Avatar
Yes all speakers are 6.5
Old Aug 11, 2013 | 06:28 PM
tigersharkdude's Avatar
Ive never taken the mirror cover off when removing the front panels
Old Aug 11, 2013 | 06:32 PM
Fakie J Farkerton's Avatar
Old Aug 11, 2013 | 07:27 PM
Aflion's Avatar
You don't have to, but i found it makes it a little easier to put the panel back on. Being this is the first time he is going to do this, i figured I'd make it as easy as possible. Or try to. Lol.
Old Aug 15, 2013 | 08:26 PM
ProV1x's Avatar
Finally got the JL Audio's delivered today. Will install 'em this wknd, thx for all the help
Matt93SE
May 24, 2019 02:58 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
Abdelrhman
Aug 17, 2015 12:16 PM
