maxiscan ms300 says " link error" on my 95
Old Aug 14, 2013 | 10:40 AM
max ride 41's Avatar
won't connect to my ecu in my 95, thought this code reader would work as it's a obd2 maxima. am i not pressing the right buttons? i just hit enter when i plug it in and that's all i saw chris do with the one he's got. his is a 96 though.
Old Aug 14, 2013 | 10:52 AM
Fakie J Farkerton's Avatar
Turn your ignition on...?
Old Aug 14, 2013 | 01:13 PM
tosheto's Avatar
I had the same issue with a 96 I had some time ago. The OBD2 scanner could not connect. I tried with the self-diagnostics screw and it worked just fine. Not sure if that helps.
Old Aug 14, 2013 | 05:04 PM
smart ****...
Old Aug 14, 2013 | 05:13 PM
arcticracer's Avatar
Try putting a little pressure to the connector in, back, forward, etc holding each for several seconds and watching the scanner as you do it. If you find a position that works you may have to hold it until it is finished. It is just a loose wire connector within in the obd port.
Old Aug 16, 2013 | 02:11 AM
QueensMAX's Avatar
check the ENG CONT. fuse at the wayy top top right corner of the interior fuse box...
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
rbaker100
Sep 25, 2015 07:52 PM
minsbang
Sep 5, 2015 05:36 AM
