1996 max
Old Nov 15, 2013 | 03:57 PM
NFury08's Avatar
1996 max
For 17inch wheels what spacers would I need?is it 15mm or 10mm and how big the tires should be I was thinking 235/45/17 with a 2.0in drop in the front
Old Nov 15, 2013 | 04:29 PM
njmaxseltd's Avatar
Spacers? 235/45/17 is the correct size
Old Nov 15, 2013 | 06:00 PM
tigersharkdude's Avatar
Nobody can tell you what you need without knowing the size of the wheels and the offset
Old Nov 15, 2013 | 06:06 PM
Trini Boom's Avatar
Do all Maxima OEM wheels have the same offset from 5th and 6th gen? I heard someone mentioning that these bigger wheels damage the wheel bearings much quicker and wanted to verify that.
Old Nov 15, 2013 | 06:57 PM
Post the specs of the wheels (width/offset) and we can help from there.
But if they're OEM Maxima 17s, I imagine you needing 25mm for the rear and 15mm for the front (at least).
Old Nov 16, 2013 | 03:40 AM
jfactor's Avatar
Currently running 17" stockers off '05 G35 coupe with 225/50-17 Hankook Ventus HRII H405. No handling issues, other than the front passenger tire slighty rubbing the plastic panel in the wheel well when making a hard (all the way) left. even with the diameter being around 3/4" bigger than stock. I'll have to see if I can hunt down the width and offset to give you an idea.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
