Low heat, low temp on gauge
Old Dec 27, 2013 | 04:16 PM
pottzie's Avatar
'97 Maxima, temp gauge doesn't move much from zero, and the motor doesn't seem to get very warm to the touch. Just getting it going after doing a trans swap. Car came from a southern state, and I didn't notice that the cooling system was filled with straight tap water. It got down to a few degrees above zero here while I was working on the transmission.
Drained the tap water and refilled with antifreeze. drove it, noticed that the temp never came up. Got a leak proof funnel, used that to verify that all the air was out, still no heat. Then noticed that I had antifreeze leaking from the top of the radiator, so I got another radiator, and before installing, took the "new" radiator to a radiator shop to have it cleaned and checked before I installed it.
Now after installing it, I still have low heat. The upper hose feels hotter than the lower hose, and I guess the next step is the thermostat, but when I drove it home with the bad transmission, the heat and temp were working fine. Then too, all I had was first gear, and the motor was revving pretty good, even though I was babying it.
It looks like the thermostat might not be as bad as Chilton's says, I just saw a Youtube where someone did it on a 2000 by just removing the bolts and lower hose-Chilton says to remove the belts. But it looks pricey, as it's an integral unit, not just a separate thermostat, and it seems strange that it worked before, but now it doesn't. Then again, if the thermostat is stuck open, I guess this is what I have. But before I bust out the wrenches, I though I'd ask here and see what someone who deals in this stuff would do.
Thanks.
Old Dec 27, 2013 | 05:38 PM
Zach-R's Avatar
Stuck open t stat sounds like the culprit. Start there and follow up with us.
Old Dec 27, 2013 | 05:46 PM
njmaxseltd's Avatar
Rad wasn't necessary, thermostat is your issue.
Old Dec 27, 2013 | 06:00 PM
chrome91's Avatar
T-stat is stuck open
Old Dec 28, 2013 | 03:22 PM
pottzie's Avatar
Yep, changed thermostat, temp finally goes to middle of heat gauge. Thanks for the tip.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
