How do you perform a compression test?
Old Jan 18, 2002 | 09:05 AM
ejj's Avatar
ejj
I have the general idea of performing a compression test, but are there any Maxima specific issues?
I have a FSM, but just wondering if there are any tips that people have found from doing them...
Thanks.
Old Jan 18, 2002 | 09:11 AM
95emeraldgxe's Avatar
search is your friend =)
Old Jan 18, 2002 | 09:21 AM
ejj's Avatar
ejj
Well aren't you helpful!
I did, didn't find a whole lot...just a bunch of threads that say "Did you do a Compression test..." or, I just did a CT and got these numbers...
Old Jan 18, 2002 | 10:17 AM
wicked1044's Avatar
take all the plugs out and your fuel fuse out.
then screw in the tester and crank the car about 5 times.
then move to the next and do the same.
Old Jan 18, 2002 | 01:00 PM
Nealoc187's Avatar
SLOW
Some say you crank it 5, some say 10, some say crank until it doesn't go up anymore. All depends on what source you look at. The main thing here is that you keep it consistent and that all your numbers are close together.
Old Jan 19, 2002 | 09:51 PM
White96MaxSE's Avatar
I was told that the minimum PSI should be 143 psi, and factory spec is 185 psi.
White96MaxSE
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
