İntake manifold cleaning ?
Old Jan 20, 2014 | 06:58 AM
Canky's Avatar
hi .. we have a32 maxima 1996..Car havent got ,performans,fuel is nice but when i cleaning the throttle i saw inside manifold and it was very dirty..What can i do for this ?..can i cleaning this..if i cleaning this,will a problem ?
the next part throttle
Old Jan 20, 2014 | 08:41 AM
Slamrod's Avatar
Are you from down under? Thats one alien looking engine bay lol.
Yes you can clean both, check the useful links sicky. You will need new gaskets put on when you reinstall those parts or your car wont run proper. They sell cans of aerosol specifically for cleaning throttle bodys and such, sold at most auto stores and major retailers.
Old Jan 20, 2014 | 09:02 AM
Fakie J Farkerton's Avatar
Mevi!
Old Jan 20, 2014 | 09:17 AM
Canky's Avatar
Well, okay thanks for the info ..What happens if you change the manifold gasket
Old Jan 20, 2014 | 09:37 AM
Slamrod's Avatar
Originally Posted by Fakie J Farkerton
Mevi!
Ahh! Im used to seeing those with the big valve cover plate that goes with them lol.
What happens if you change the gasket? Then youll be fine lol. If you meant what happens if you DONT change it, well you run the risk of having a vacuum leak which means improper engine pressure which is bad. Any time you remove parts like this youll want to have new gaskets, unless you already replaced them recently.
Old Jan 20, 2014 | 03:08 PM
njmaxseltd's Avatar
It's only air going through the manifold and that doesn't look all that bad. Your not going to see any benifits by cleaning that area. You will see more improvements at idle by keeping the throttle body and Idle Air Control Valve clean. A much easier task with noticeable improvements.
Old Jan 21, 2014 | 01:30 AM
Canky's Avatar
then you are no better not hand .. thank you again
Old Jan 22, 2014 | 10:16 AM
JvG's Avatar
JvG
Interesting..... you have a 2000cc engine. The ones in North America are
3000cc.
Which country do you live in?
Old Jan 22, 2014 | 10:54 AM
Claybob86's Avatar
I believe he is in Turkey. Wonder if they have Seafoam over there?
aw11power
Oct 10, 2021 04:57 AM
BobTX10
Oct 7, 2015 08:43 AM
JonBlz
Oct 5, 2015 06:02 PM
fx4five
Oct 1, 2015 04:58 AM
