Misfire but no code
Old Feb 15, 2014 | 06:08 AM
Schade1's Avatar
Misfire but no code
I have a 99 maxima with 124,000 miles on it. I have a misfire but no code. I had changed the plugs about 3 months ago but it has gotten worse. The fuel economy has gone way down. I have heard many people say ignition coil. But I should have a code. HELP. I am going crazy. I have found a 6 pack of new coils on Amazon for 82 dollars. But wonder if it is worth a try. Any ideas?
Old Feb 15, 2014 | 07:28 AM
ADROX's Avatar
you can check each cylinder to see if its coming from a certain one by unplugging one coil at a time while the car is running. if the idle/miss does not change for a certain cylinder then your problem is most likely there. nissan coils are a must, some people say hashings are good too just dont use aftermarket ones. also check for vacuum leaks using carb cleaner (be careful its very flamable) and make sure all connections on sensors/harnesses are good. that's a few things that you can easily do yourself for free.
Old Feb 15, 2014 | 08:28 AM
Schade1's Avatar
Nissan coils? Do I get them from a local dealer? Those sound like good ideas. I'll try that and see what I come up with. Thanks.
Old Feb 15, 2014 | 09:15 AM
Maxima 97 SE's Avatar
Go on eBay there's some people selling really good used ones for really cheap http://www.ebay.com/itm/331120823808...84.m1555.l2649
Old Feb 15, 2014 | 10:51 AM
MaxDD's Avatar
Hopefully you used ngk plugs. i agree with adrox... do a power balance test to isolate any problem cylinders. could also be your injector(s)
Old Feb 15, 2014 | 11:14 AM
ADROX's Avatar
Originally Posted by maxdd
hopefully you used ngk plugs. I agree with adrox... Do a power balance test to isolate any problem cylinders. Could also be your injector(s)
yes ngk plugs. Do the free n easy stuff first.
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
