Connecting rod ball joint bad?
Old Feb 23, 2014 | 07:09 PM
DBear's Avatar
Does this look like too much play in the ball joint? http://s397.photobucket.com/user/Dbe...]=1&sort=1&o=0
Old Feb 23, 2014 | 07:21 PM
vq4thgen4life's Avatar
That would be your front sway bar endlink. And yes its worn out and needs to be replaced.
Fairly easy job too, DIY worthy.
Old Feb 23, 2014 | 09:44 PM
DennisMik's Avatar
I agree. Plus the rubber bushings above where you were pitting the wrench are worn out, too. An end link kit will include those. Do both sides. The kits are not that expensive, either.
And it looks like the boot on the axle CV joint is ripped up. There's another project for you.
Old Feb 24, 2014 | 03:50 AM
6cyl-97maxima's Avatar
I just put an end link kit on my car about 3 months ago. As stated before it's very DIY able. Also as Denis mentioned buy a sway link kit. And get erything you meed. Have fun with the axle. I had to do both of mine also.
Old Feb 24, 2014 | 12:39 PM
DBear's Avatar
OK thanks. I just replaced the sway bar end bushings. IIRC, I took this when I was starting to take things apart. That's how I noticed the movement. The CV boot is relatively new. I'll have to check that. I didn't notice it was torn when I was in there, but I might have missed it.
James92SE
142
Jan 2, 2024 09:23 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Andy29
Sep 29, 2015 05:32 AM
ivorton23
Sep 26, 2015 09:47 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
