Cel questions??
Old Apr 14, 2014 | 10:39 AM
CPHATCH's Avatar
Cel questions??
I'm trying to figure out exactly what my issue is with a P0400 code. I also have a p0325 code which is a knock sensor. (understand that one). I have replaced the egr valve and cleaned the egr tube (which was clogged on the top port) but today after driving for a few miles the light came on again. I spoke with someone at the auto parts store and he said to check the breather tube at the gas tank filler hose? Have any of you had this problem and what did you do to correct it? Also what other things can I check. I don't want to keep throwing money at this but time is running out on my inspection.
Any constructive comments would be appreciated.
Old Apr 14, 2014 | 10:53 AM
Maxima 97 SE's Avatar
Check your egr solenoid switch. It's small little green box that controls the function of the egr system.
Old Apr 17, 2014 | 10:21 AM
CPHATCH's Avatar
Egr issues
Someone said that you could check for continuity on that switch which I did and it does show continuity. Is that a good check or is there something else I can do?
Old Apr 17, 2014 | 02:22 PM
DennisMik's Avatar
Checking continuity is only testing half of the switch, the electrical side. The device has 3 vacuum hoses on in and it will switch one of the lines between the other two. This switching part could be bad and a continuity test would never show it.
In the service manual, it shows how to test the switching section. Click on the link below and follow the directions on page 261.
The link is to a 1998 manual. You didn't say what year your car is, but you got lucky this time as this is the same for all the years.
http://boredmder.com/FSMs/Nissan/Maxima/1998/EC.pdf
Old Apr 17, 2014 | 05:24 PM
ac max 92's Avatar
p0400 egr valve flow A
jmlee44
Oct 2, 2022 02:13 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
