Crank Sensor
Old Apr 30, 2014 | 01:30 PM
jacksonwr2's Avatar
Crank Sensor
Can anyone tell me the complexity of changing out front and rear crank sensors
Old Apr 30, 2014 | 01:36 PM
njmaxseltd's Avatar
On a scale of 1 - 10, it's a 2.
Old Apr 30, 2014 | 03:36 PM
bewrong's Avatar
Which end is which?
Old May 1, 2014 | 05:34 AM
Patm-a32's Avatar
very simple to do check the wiring as well my wiring was faulty causing my car to crank and not start
Old May 1, 2014 | 05:35 AM
Patm-a32's Avatar
Oil coroded my wires
Old May 1, 2014 | 08:30 AM
CS_AR's Avatar
I cleaned mine and was surprised to see some buildup on one of the sensor ends. Also, I cleaned the plug pins at the same time.
Old May 2, 2014 | 06:06 PM
Bone Collector's Avatar
Of course changing a sensor is as simple as could be. What are you guys doing about damaged wires though?
Old May 5, 2014 | 07:07 AM
Patm-a32's Avatar
Locate the bad wire (usually the red one if i remember correctly) simply find where it had gone bad cut it out and sotter in new wires throw some heat shrink and some electrical tape on there and ur good to go.... Easiest done on a lift... Rather then laying under the car messing with the wires. If u cant DIY a shop shouldnt charge much to take care of the wiring
Old May 5, 2014 | 07:11 AM
Patm-a32's Avatar
Took me about an hour, about 20 minuets to get out the bad wire and
In the new wire then took a little while wrapping up the wires and tucking the away from the oil filter so there no longer being sludged up with oil
Old May 5, 2014 | 07:24 AM
catalinvint's Avatar
Had the same problem on mine. Went to the junkyard cut one off a 4th gen and patched it.
Old May 5, 2014 | 08:14 AM
Patm-a32's Avatar
^^ This works just as well too
my03maxima
Jul 28, 2024 07:40 AM
TKHanson
Nov 24, 2018 01:39 AM
zmcneely13
Sep 26, 2015 02:26 PM
