Wheels stick out
Hey guys i have 18in g35 infinity wheels and the front wheels only** not the back wheels poke out almost as if i have spacers but i dont... This is keeping me from lowering cause they stick out a lot and ive seen other 4th gens with the same wheels that dont do this... I dont have spacers but i have after market drilled and slotted rotors that possibly are thicker than stock can this be my issue ? Or something else any help is apriciated thanks guys
Any pics of this? Which wheels do you have and are they staggered and if so, do you have the wider ones up front?
Originally Posted by NmexMAX
(Post 8947270)
Maybe you need negative camber up front?
Pics no work.
2 Attachment(s)
Originally Posted by Patm-a32
(Post 8947281)
http://s62.photobucket.com/user/Mill...]=1&sort=1&o=0 front
http://s62.photobucket.com/user/Mill...]=1&sort=1&o=1 back Attachment 23661 |
Originally Posted by CustomLowz
(Post 8947315)
http://i62.photobucket.com/albums/h8...ps2600de06.jpg
http://i62.photobucket.com/albums/h8...psbe850021.jpg |
you've got wheels that are an inappropriate width and offset combo for your car bud.
(Post 8947315)
When you lower the car the wheels come in a bit. My experience with G/Z wheels is they rub upfront if you run anything larger than a 235, The rear fenders MUST be rolled otherwise that sharp fender will chew your tires up fast.
(Post 8947333)
Originally Posted by Calabar
(Post 8947334)
I know this is off topic but where did you but g35 wheels and how much
(Post 8947347)
You sure man? My buddy i bought these off had them on his 99 se as well as me and they fit snug in his wheel wells and he had the car lowered
sure seems that way to me. did he have a lot of negative front camber? you drop the car and the top of the front wheels are going to camber in a bit. they won't stay vertical. |
(Post 8947333)
I have G35c rims on my Max and they fit great. I only rolled my fenders for peace of mind, didn't really have to though. See post #34 http://forums.maxima.org/members-rid...w-boosted.html |
(Post 8947353)
I did buy after market rotors for the front and they are wider than the oe rotor can that mabey be the cause ?
No, pull all wheels make sure there not staggered. I've never seen this happen and I've had all kind of wheels on my car. Hell, this is a good thing actually. Smaller tire, rear spacers and drop, your set...
4 Attachment(s)
My fronts stick out more than the rear. They are not staggered, all four are 17X8" with 235/45ZR17.
Attachment 23644 Attachment 23645 Attachment 23646 Attachment 23647 |
(Post 8947358)
It can't be the rotor(s) guys...Think about it...
I have a feeling the wheels are really staggered. Have you confirmed the offsets? They're stamped on the inside of one of the legs. |
(Post 8947265)
I know they are all the same if i rotate the wheels they still do this
I might just get rear spacers to even them out ... What mm spacers should i use if i do this
Which G35 wheels are they?
If you want to run a spacer, break out a ruler and measure how much you'll need then convert. 1" = 25mm. |
Okay so im thinking possibly my rotors could be causing this ?? The outer part of the rotor the part the part the wheel touches on the oe maxima rotors is 280mm and the rotors i have the outer diameter is 295.5mm can this be my cause??
(Post 8947443)
(Post 8947446)
http://www.rx8club.com/attachments/r...icstandard-jpg |
(Post 8947446)
How thick is the center section of the rotor- the part where the wheel studs go through? factory rotor thickness is roughly 1/4" there. to cause this problem, those aftermarket rotors would have to be an inch thick there, and I guarantee you they are not. |
Have power stop drilled and slotted... Idk how to check the measurments
Rotors will not do this, they sit flush with the hub, it they were too wide for car, they would hit brackets among other things...Need to do more homework on your wheels, seems like just a fitment issue. show full pics of the wheels front and back, with numbers...
PLEASE listen to the multiple requests you've gotten to LOOK and VERIFY and give PICS of said wheels. Wheel info / specs / tire size also.
Also something to consider...the rears in the 4th gen are about 10mm further "inward" than the fronts... so the disparity could be somewhat attributable to that fact. |
Originally Posted by dwapenyi
(Post 8947455)
No that's the width of the disc itself. See the pic below? The measurements you gave are A. The problem seems to be C, the thickness of the hub;
http://www.rx8club.com/attachments/r...icstandard-jpg C - Positions the braking surface area properly between the pads on the caliper. You have the incorrect wheel offset, (or a spacer your not seeing) that's what's throwing them out, nothing else. |
I've seen an offset number stamped/molded in the inside of my Infiniti/Maxima wheels (on a spoke) to show the wheel width and offset. For example I have some Infiniti wheels that are 18/7.5/35 (for 35 MM Offset)
Can you show the numbers from inside the wheel? |
(Post 8947492)
If you lower it, the wheel should move inward clearing the fender. |
How much of a spacer should i use ? If u can tell based on the pic of the back wheel
(Post 8947743)
So no pics and proof of the actual offsets?
(Post 8947979)
(Post 8947979)
Probebly will just go with the 10mm spacers in the back and lower it then and see what happens |
© 2024 MH Sub I, LLC dba Internet Brands
