Leaking valve cover gasket
Old May 3, 2014 | 12:13 PM
Patm-a32's Avatar
Hey guys just got back from the shop i just went and got every thing inspected like i usually do every month or so... And come to find out my valve cover gasket seems to be leaking oil... Now it isnt dripping or leaving spots on the drivway or nothing but its clear that it is leaking, i do plan to fix this my question is, is it dangerous to have it like this for mabey a month at least till i can get some money together ?
Old May 3, 2014 | 12:32 PM
DennisMik's Avatar
It's not dangerous, just messy. As the oil leak gets worse, the wind that gets under the car will spread the oil around, on the suspension,the car body and whatever else. And if it leaks bad enough, you will have oil on the ground after you park the car.
Old May 3, 2014 | 01:05 PM
Patm-a32's Avatar
Its not leaking that bad theres no oil on anything around it or on the ground after i park or nothin u can just see oil there like it has a small small leak the mechanic said i dont really have to worry about it atm causenits so small but i plan to fix it next month do u think I'll be good till then?
Old May 3, 2014 | 01:35 PM
tosheto's Avatar
You are fine. My 4th gen was leaking for a long time and leaving puddle under the car and I never had any problems.
Old May 3, 2014 | 08:40 PM
pjgreek's Avatar
If your front cover is leaking onto your alternator, better to replace it sooner rather than later before you ruin your alternator (don't ask me how I know).
Old May 3, 2014 | 09:19 PM
asand1's Avatar
Leaking valve cover gasket can ruin motor mounts, oxygen sensors, and control arm bushings too. If it is a small leak your probably good for a few months.
tgreen
Oct 18, 2015 06:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
