97 maxima brake light issue
Old May 6, 2014 | 10:55 AM
nhJOE's Avatar
last week my car died on the road and was told i needed a new alternator. replaced that car ran good. then noticed my brake lights werent working. i checked the fuse box under the dash and under the hood but cant find what fuse it is . all i see are tail lights but cant figure out which is the brake lights fuse
Old May 6, 2014 | 11:03 AM
Tail light fuse = brake light fuse. Check and replace. Sould be under the hood IIRC.
EDIT: ^ Incorrect.
Old May 6, 2014 | 03:31 PM
DennisMik's Avatar
ChrisMan - you've got this confused with something else, brake lights and tail lights do not use the same fuse.
The tail lights use fuse # 5, 7.5 amps. this fuse also powers the dash lights and the door chime.
The brake lights use fuse # 10, 15 amp. This fuse also powers the cruise control and the ABS unit.
Both fuses are in the dash fuse block, to the left of the steering column.
Fuse # 5 is in the left-most column, 5th one up from the bottom.
Fuse # 10 is also in the left-most column, 10th one up from the bottom.
Old May 6, 2014 | 04:27 PM
nhJOE's Avatar
so u guys have me confused which one is the brake lights
Old May 6, 2014 | 05:16 PM
njmaxseltd's Avatar
Don't rule out the switch on the brake pedal or the bulbs.
Old May 6, 2014 | 05:45 PM
I'm probably thinking 5th gen. My bad.
Old May 7, 2014 | 07:33 AM
DennisMik's Avatar
Brain fart! I should have read what I wrote more carefully.
egali045
Aug 16, 2015 01:19 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
RealityCheck
Aug 5, 2015 06:18 AM
