Have oil leaking into the rear pass side coil well.
Old Jun 1, 2014 | 04:05 PM
Cheyo1969's Avatar
I have oil leaking into the coil well on my 96 maxima, I have changed the valve cover gasket and well seals but they did not solve the problem. I would appreciate any ideas to get this fixed. All the other wells are fine no oil at all in them.
Old Jun 1, 2014 | 06:51 PM
CS_AR's Avatar
Can you shine a light into the well to see if there is a gap at the top between the well top and the seal that is not present on the other wells that do not leak?
Also, I remember feeling along the inside well surface to gauge any distance and check for leaks between the well top and the seal.
Old Jun 2, 2014 | 12:55 PM
DBear's Avatar
IIRC, the last time I changed spark plug tube seals I used aftermarket, and one leaked. I ended up putting in Nissan OEM. And make sure you install them the right way. I forget whether the opening goes up or down. There's a thread about that somewhere.
Old Jun 2, 2014 | 05:07 PM
Cheyo1969's Avatar
Troubleshooting
I'll try both using a light and checking for cracks as soon as I am back home thanks.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
