what mods??
Old Jun 14, 2014 | 01:42 PM
8maxed1out7's Avatar
what mods??
I wanna go all motor I got a 95 maxima auto trans what mods should I do?? Hint: injectors manifold exhaust pistons n trans exc.. Plz serious post. post whats under your hood??
Old Jun 14, 2014 | 02:33 PM
Quickywd01's Avatar
You won't need injectors untill your done with all motor mods because they're sufficient. Don't need pistons or anything like that. You can do a drop resitor mod and wire it to a switch so you only activate it during hard accelerations. You need a trans cooler and good synthetic fluid like amsoil. You pull off a cooler hose and start the engine and the trans pump will pump out all the fluid while you fill it. Do a drain and fill, then while your hose is in a bucket you start the engine and start pouring fluid into the dipstick hole. You have to stop the engine every so often because it pumps out faster than you can pour it in. Then do either obx vq3.5 headers (unless you have cattman money), they fit don't let the 3.5 fool you. Then a cat-back. If you don't do headers you want to have factory fed spec exhaust manifolds, a y-pipe like warpspeed, and a cat-back. Then a '00-'01 Variable intake manifold swap. A vafc2 or EMU. That should net you a good amount of power. Then loose some weight. Engine stock I've seen handle 600hp so all motor don't worry about internals. http://www.dynomagic.com/thefast_hlh.htm
http://www.youtube.com/watch?v=ChZ_GvP_fkQ&feature=kp
Enjoy! Any more questions, feel free to ask.
Old Jun 14, 2014 | 06:52 PM
Alaskus's Avatar
Start with maintenance on a 1995.
Read the how-to's, clean up the engine. See what needs repairing/replacing first. Get to know your engine and then invest in bolt-ons. No sense in buying anything if something like motor mounts need replacing or steering rack is leaking...
Old Jun 15, 2014 | 01:26 AM
Quickywd01's Avatar
Oh yea get ES poly bushings for the engine/trans mounts. You might as well get their bushing kit and the do the subframe, control arms, sway bar, etc.
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
