noobie that's confused..have a question about timing
Old Jun 17, 2014 | 12:29 PM
bobjob's Avatar
Got a '95 maxima with a vq30de engine ..I have NEVER worked on a 24 valve , twin cam car before .. It started leaking water really bad from behind inner timing cover .. removed outer and inner covers .. bad water pump ...old gasket material ..
All information I have on timing marks ,, leave me a bit confused ... what would I do if I'm off ..I only removed the 1 chain from crank to water pump - and front cam sprockets ... any help would be greatly appreciated .........
Old Jun 26, 2014 | 11:43 AM
Quickywd01's Avatar
http://forums.maxima.org/4th-generat...ngine-tdc.html
Old Jun 26, 2014 | 12:12 PM
NSMO240's Avatar
go off the marks shown on the write up, you may see paint marks that when in time are off, this is usually from the factory marking that the chain has been installed close to correct timing and minor adjustment is needed later on the assembly line.
Old Jun 27, 2014 | 02:24 AM
dwapenyi's Avatar
Download your FSM here;
http://boredmder.com/FSMs/Nissan/Maxima/
It'll tell you how to line up everything.
max_speed97
Aug 26, 2015 07:46 PM
doobadoo
Aug 15, 2015 06:43 PM
wingnut2006
Aug 15, 2015 04:16 PM
mikekay
Aug 10, 2015 12:52 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
