security problems
Old Jul 16, 2014 | 04:20 PM
hoff1704's Avatar
security problems
Does anyone know how to reboot the alarm system?. Fukin mechanic changed out the maf sensor,ignition and fuel pump,thinking it was one of those things and didn't disconnect the battery... so now my car is still broke,and.so am I!!! Any advice will be gladly appreciate
Old Jul 16, 2014 | 04:33 PM
JoshG's Avatar
is ur car a 99? it may be immobilized
if not I had the security system on my 96 block me from starting my car when the alarm went off by accident.. it was quite cool to see that even a 96 security can stop the car from starting. but all I had to do was, get out of the car. lock the car..then unlock it with the car key and open it.. start car.. boom reset and car started.
Old Jul 16, 2014 | 05:38 PM
hoff1704's Avatar
thanks
Ill try that when I get home, I also wonder if the ignition I got is causing problems bcuz it is not a chipped key,jusy a regular one
Old Jul 16, 2014 | 06:15 PM
dwapenyi's Avatar
The ignition doesn't read the chip, a remote sensor does, so it doesn't matter (to the ignition) whether the key is chipped or not.
Now, if you have a chipped key before and you've just replaced it with a regular non chipped key, then that will disable your 1999 maxima.
Old Jul 16, 2014 | 06:24 PM
njmaxseltd's Avatar
Here's IMHO the best advise for you...
FIND ANOTHER MECHANIC!!
Throwing parts at a car isn't a very knowledgable way of fixing it.
Old Jul 16, 2014 | 07:23 PM
yellow_cake's Avatar
If your car is a 99 (chipped key) and your new ignition switch takes a new key (non-chipped or non-programmed) try this:
Put your new key into the ignition switch, then hold your old key (chipped) right next to the ignition switch and turn it.
It should start (that's if it was a transponder key issue).
Old Jul 16, 2014 | 11:25 PM
dwapenyi's Avatar
Excellent idea for a workaround
Old Jul 21, 2014 | 04:09 PM
hoff1704's Avatar
reply
Thanks for that advice,I will try to hold the original key to the ignition and see what happens. I had 3 different"experienced" mechanics look at it, but apparently they were just crack pots. If that wont start the car,my next option will be to just part out the car.. ill let ya know how it goes when I get home
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Junebug1701
Sep 25, 2015 01:54 PM
