cd player problem
Old Aug 3, 2014 | 08:41 PM
Maxtuckin19s's Avatar
cd player problem
Ok so I got a wire harness from Walmart so I could put a aftermarket deck in my Max so I did everything I was supposed to but now wwhen I plugged it into the deck it's not turning on , you hear the cd eject motor kick on for a second an that's it , and on the new harness I have a black wire with white stripe that has nowhere to connect to , please help me someone
Old Aug 3, 2014 | 09:07 PM
95Maxima305's Avatar
That sounds like the factory amp ground wire. What kind of radio are you installing?
Old Aug 4, 2014 | 10:48 AM
DennisMik's Avatar
Is this black/white stripe wire part of the connector that plugs into the radio or is it part of the Metra adapter that plugs into the Nissan wire harness?
Also, What year is your car? Are you replacing a Bose or non-Bose radio?
Old Aug 4, 2014 | 04:57 PM
asand1's Avatar
Scosche NN032? I have this adapter from Wal*Mart, and I don't have the Black/White wire connected as the directions said not to. It is listed as ;
6 wire plug:White Black
6. Black/White = Display Lighting Ground, Not Used.
My stereo works fine.
Did you connect the rest of the wires using the harness adapter and stereo instructions? How did you connect them, solder or crimp? I have seen people try to twist and superglue. Not very bright, but its worth asking.
Did you have factory Bose?
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
